01-23-2019 04:52 PM
I have an EOS 70D that has become somewhat ambivalent about talking to the attached lenses. The camera cannot determine, or assign, the aperture setting. The aperture is displayed as '0'. Spinning the aperture wheel on the camera back accomplishes nothing -- it stays rock-steady at '0'.
If I swap lenses sometimes the camera will immediately pick up and display the aperture settings and the aperture wheel functions normally. Sometimes the camera is not so successful in linking up with the attached lens. I have found that taking a shot while the aperture displays '0' sometimes jars the camera back to reality and it correctly displays the aperture setting and the wheel becomes functional again.
I initially thought it might be an issue with the lens, but after trying multiple lenses I've noted that the symptom can crop up with any of them. I have attempted to clean the contacts on both the camera and the lenses, but without success.
The problem is intermittent. Sometimes the camera and lens get along just fine. Sometimes they seem to need counseling.
Thoughts?
01-23-2019 05:26 PM
WAG here, could the lens mount on the camera be a little loose? That might make the contacts pull away from each other.
01-23-2019 05:30 PM
Hey, I like the line of thinking there. I took a quick check of both the camera and the lenses and everything appears to be snugged down tight. Thanks for the suggestion, though.
01-23-2019 05:52 PM
That is the only thing I can think of that does not involve internal surgery on the camera.
01-23-2019 08:25 PM
@Bankcraft wrote:Hey, I like the line of thinking there. I took a quick check of both the camera and the lenses and everything appears to be snugged down tight. Thanks for the suggestion, though.
Hmm. The contacts in the camera’s mount should not be “snugged down tight.” They should be behave like they are spring loaded. You should be able to press on them until they fully sink into the body, and then spring back out when you release them.
01-23-2019 08:56 PM
01-24-2019 10:30 AM
"...after trying multiple lenses I've noted that the symptom can crop up ..."
All Canon lenses?
01-24-2019 02:41 PM
Yep.
01-25-2019 11:19 AM
You need to call Canon 1 (800) 652-2666
