EOS DSLR & Mirrorless Cameras
Resolved! canon 5D mark IV
I have a canon 5D Mark IV camera and I bought a canon EF 24-70mm f/2.8L lens and it gives me err 01 and to clean the contacts. I have cleaned them multiple times but then realized that it would shoot in TV mode but not Manual mode.. Does anyone know ...
Fellow with new T7
I want to thanks to all on the forum, especially with all the questions on my T7, etc. Met the father of my grandson's friends at a ball game. He just got ia T7, body and 75-300mm lens for starters. I was able to share a lot of what I got from the fo...
Tie Aperture and Speed in Manual Mode - EOS 6D
Hello: This is about the Manual exposure mode in EOS 6D.  Sometimes it would be convenient to automatically adjust the aperture when the speed is changed and vice versa.  For example, I set the aperture and speed, take a shot, and than decide I need ...
FPP by Apprentice
  • 12492 Views
  • 10 replies
EOS R5 Firmware V. 1.3.1 Bug Fix
R5 owners:  If you have not checked the Canon Support website for firmware updates recently:  EOS R5 V. 1.3.1 has been released.  It fixes the screen brighntess error (bug) in the viewfinder and and LCD that happens when shooting video in Canon LOG 3...
Lotus7 by Rising Star
  • 1514 Views
  • 0 replies
EOS 90D LCD working for Video but not Stills
I have an EOS 90D. Whenever I have it set to video, the LCD works perfectly fine. But then when I switch it to still camera, the LCD goes - and stays - completely black... Or if I start with the whole camera off and try turning it on with the setting...
Pking by Contributor
  • 4169 Views
  • 5 replies
Resolved! Printed Image is not as clear as screen image
I have a Rebel EOS SL2 and I have a picture that I was submitting to an exhibit and the pixels under properties for this image is 3555 x 3983 pixels.  I used GIMP to confirm that the dpi for my 8 x 10 printed picture would be at least 300 dpi and it ...
debaroo by Contributor
  • 10861 Views
  • 23 replies
Resolved! Need advise on new lens for Canon EOS Rebel SL2
I currently have an EFS 18-55mm lens, an EF 75-300mm f/4-5.6 lens and a Vivitar 420-800mm F8.3 (manual) Super Telephoto lens.  I am wanting to invest in a new lens for my camera and I mostly take closeup wildlife or flora photos.  I also like to take...
  • 5681 Views
  • 3 replies
SD CARD RECOVERY?
Hello, I have a 64GB SanDisk Ultra Plus MicroSD card that I haven't used in a while. I recently came across it and put in my laptop to see what was on there. It's telling me there are 49.77gb used, however when I click into the card no photos appear....
Screen Shot 2021-04-30 at 9.46.16 AM.png Screen Shot 2021-04-30 at 9.47.48 AM.png Screen Shot 2021-04-30 at 9.46.10 AM.png Screen Shot 2021-04-30 at 9.46.22 AM.png
sarahr_7 by Enthusiast
  • 12112 Views
  • 9 replies
Resolved! L-Bracket for 90D with battery grip
I'm looking for an L-Bracket that will work with my 90D when the battery grip is mounted. By work I mean that the battery sleeve can be removed from the camera without having to remove the bracket. I have a generic long bracket but there is no openin...
Carbon14 by Contributor
  • 6516 Views
  • 5 replies
EOS RP -Which Settings Controls to use?
I've had my EOS RP for a little while, and I continually get confused about which controls to use for what settings -- can someone explain a general rule of thumb for each -- Qset, Menu, M-Fn. And then in Menu, what's the logic of the controls across...
shele by Contributor
  • 7888 Views
  • 5 replies
How to delete a folder on CF card in R5
I want to delete a test folder that I set up on the CF card in my R5.  I tried formating the card.  I removed all photos and tried formatting the card.  It just won't seem to go away.  I cannot find any instructions on how to do so.  Suggestions?
Steve531 by Contributor
  • 7197 Views
  • 12 replies
R5 Still Photo IS not working with RF 28-70 F2
R5 Still Photo IS does not seem to be working with RF 28-70 F2 Lens. When I set it to always on IS works great. See attached side by side image. Camera settings are below images. You can see that I could not even get a sharp image @ 1/200s with the R...
Sruddy by Apprentice
  • 2562 Views
  • 5 replies
