EOS DSLR & Mirrorless Cameras
Loading pics onto laptop
Hello. New here and hoping to get advice leading to solution? Have 5D MarkII and for first time my MacBook is unable to see either my camera or card reader. Have tried two different cards. I can see pics on camera, but somehow my MacBook is now not s...
Sample1 by • Apprentice
  • 1392 Views
  • 2 replies
Resolved! SD Card Full
Hello everyone!I use 32 GB SD card for my Canon EOS R after taking 67 pictures it is saying "Card Full". And the images i save are in RAW type. i have heard that a 32 GB should store a min of 1000 images.Any insight will be helpful please!Thanks!Sure...
Canon EOS Rebel T7 Blurry Photos
I just started with this camera. When I take photos, they look fine. But, when I transfer them to my phone, Samsung Galaxy 10s+, they look blurry. So, after I first encountered this problem I switched the camera to raw. I took more photos and transfe...
unclear pictures
I have a 80D and take a lot of sports pictures.  Using a 2.8 70-200MM lens (Tamron), I use the manual mode with a shutter speed of 600, 800 and 1000 (depending on lighting in gym for instance), Fstop 2.8 and iso on auto.  1 of 15-20 are clear but oth...
Canon 70D Grainy with good lighting?
HELP!Ive come across this problema and want to understand what the issue is ..ive used my 70d in low ligth settings and a lower than 800 (640) iso ...however when i put in post i still can see grains. I thought that if you go over 800 is when you see...
T6i and external monitor won't work
I have a T6i and when I connect it to an external HD monitor using the HDMI out port no image is displayed on the external monitor. the camera acts like nothing has changed.I went into the camera settings and set the Ctrl over HDMI to Enable, but tha...
mderksen by • Apprentice
  • 23046 Views
  • 18 replies
SL3 Power Adapter Question
Hello, I have a power adapter for my SL3, and I have a question regarding power. I'm wanting to use a smart plug to power the camera on and off because the camera isn't easily reachable, but I'm not sure if that will damage the camera. Basically, wha...
Resolved! 5D mark iii overexposure
Shooting in manual, the first 10-15 pictures in a session are overexposed by as much as 3 stops. I am using the 24-70mm 1.4 L IS USM lens.  If I switch to automatic the exposure is fine. Using evaluative metering.The exposure slowly gets better until...
hutchijr by • Apprentice
  • 2394 Views
  • 4 replies
Canon EOS 90D
I have a EOS 90D without an electronic shutter. I understand the current model 90D has an electronic shutter. Is this a software upgrade that I could install, or is it not available on the camera I own?
trdeetz by • Apprentice
  • 1945 Views
  • 2 replies
Canon EOS2000D not focusing
I have a problem where my camera doesnt want to focus no matter what i do. The only time a image is ''sharp'' is when i manually addjust the zoom so it's kind of sharp. I tried connecting it(the lens) to a different body and no difference. 2000D body...
EOS-1D Mark III Err99
I have an EOS 1DMk3 that I purchased second hand many years ago.  It will work fine for a while and then throw an Err99.  I turn it on and off, I swap batteries, and still, it's Err99.  So, I park it for like 6 months, put a newly charged battery in ...
jtmiv by • Apprentice
  • 1327 Views
  • 0 replies
Resolved! Tethering connector
I tether 5dm4 to my laptop via USB port in camera but the connector at the camera side often comes loose. Then I loose the link. Is there some kind of clamp or bracket that will hold the cable and/or connector in place while I use the camera?
