camera does not add shutter count number on photos
Camera-Shutter-Count.pngcanon D1300 camera does not add shutter count number on images
I was using my Canon M6 but suddently screen turned white and stuck there. Even I turned off the camera but it was still white. Then I took out the battery, and screen went blank. After that I formatted my SD card and inserted again along with batter...
Using M6 Mark ii with EF M lens 18-55 mm, AF is no longer working, will only work on manual setting. Have cleaned contacts, still no luck. Even tried with new EF M lens 15-45 mm with no luck. AF works with 70-200 USM 2.8L lens with Fotodiox Pro EF-E...
Recently my 80D gave me the dreaded "Can't read memory card...." error. I tried different cards but it would not read any of them. I can read/write to all of them on my computer, but not my camera. I have tone card that usually stays in the camera...
Need help please when I put My sdcard in it will not work even when I try To format it.
Hi, My Cannon 80D camera failed to read the memory card.How can I fix the above situation.Thank you!
I've used the Canon SL1 for wild flowers, butterflies, and birds fairly successfully for years and generally use it with a Sigma 100-400 lens. It's been a good combination for low weight, long walks and usually obtaining decent to excellent results....
Hi all, I cant update the firmwire on my Canon R5. I use a fully loaded battery, I download the new firmwire from a Canon site, I unzip the firmwire, I format my CF Express in the camera, I put the CF express card in my computer and move the firmwire...
I have found that when taking a series of very short exposure images, at some point the camera reports BUSY, stops taking capture requests, and everything comes to a halt. I have to power cycle the Canon to recover.My take is that the Camera is repor...
I am using OS Microsoft Windows 11 and downloaded the necessary drivers. When I follow the steps to upload pictures and get to the Direct Transfer stage, there is no option that pops up for Direct Transfer. I checked my Device Manager and it shows ...
Hola, I am a scuba diver and I take underwater photography, I got sea water into the Canon Eos R as well into the macro lens, so far equipment is death, any suggestion to recover it???? do you have any idea if Can on can fix it????Thanks.
Hello!I have a Canon EOS Rebel T1i camera.I would like to acquire a new camera of the same series.Which is the newest Canon EOS Rebel T... that I can get and still be able to use the different lenses that I bought for my Canon EOS Rebel T1i?Thank you...
Hi. I returned to my camera from a long break. I recharged the battery fully and inserted. The WB blue light is on full-time and no functions are available. LCD screen blank. Can anyone help ?
Hi everyone,You can use Exposure Compensation in Av, Tv, or P Mode to slightly adjust the exposure that the camera is selecting. In Av mode, you fix Av and ISO, the camera selects the shutter speed with the correction from the overcompensation. In M ...
My Canon M50 camera suddenly not working, I've been using it for more or less 5 not consecutive days. When I turned it on the sceen flicked then went stripes before it stop working. Now it doesn't work at all, it's not turning on. It's never been dro...
| Subject | Author | Posted |
| 08-24-2026 04:18 AM | ||
| 08-24-2026 01:12 AM | ||
| 05-19-2026 01:06 PM | ||
| 05-14-2026 07:24 PM | ||
| 04-24-2026 10:39 AM |
