EOS R50- photo warmth
hi there! i'm completely new to cameras and have a canon eos r50. i want to take photos with warmth on them and more color, less neutral or grey feeling; is there a setting for this? again, total new user. please help!
Just got the r50 used and updated firmware from original firmware to 1.4.0. This has introduced an issue where regardless of settings, the internal microphones don’t record other than static. No matter the settings the meter stays still so it’s not p...
Looking for advise with Canon R6 MK II indoor wrestling. What AF case do you typically use? Which AF Method would you use it with 1-Point or zone, or single point?
Screenshot 2026-02-15 185720.pngScreenshot 2026-02-15 185700.pngScreenshot 2026-02-15 185622.pngBest focusBest focus I've included images showing the focus points. The best focused image is the last (2), showing zoomed and the full. These were on s...
Please check serial number is valid or not Canon R10 : serial number (398033[xxxxxx]) RF-S18-150 F/3.5-6.3 IS STM : serial number (52520[xxxxx]) [Serial numbers partially hidden to protect privacy.]
HI, I'm having a curious issue with my R7 LCD screen. Two horizontal grey lines appear on the screen, approx. 1mm in size, one at the top, the other the bottom, about 2mm from the edge. They appear no matter the what configuration the display "Info" ...
hi name is christian trying to update firmware but when I try it doesn't find the firmware update no matter if i format the sd card i still cant update it rebel t6. new sd card and all still not letting me the newest update and all. if anyone could...
My 24-105L just fell off my 5D mkIII and rolled into the Seine. The lens release button is way too sensitive and it is so easy to accidentally unlock without realizing it. I went to twist the zoom ring and the lens rotated and dropped off. Blo...
I am looking for advice from R8 users only. I am considering buying an R8 as a travel backup & 2nd camera to my main R5. (For studio work I use the R5 and 5Diii.) I took the R8 out for a spin to compare image IQ and overall handling with my other ca...
Hi, today I received my Canon EOS R100 (so it’s brand new). I used it for a few minutes right after opening it, and while I was sending photos to my phone through the camera app, it suddenly turned off. Even though I charged the battery for hours a...
I’ve been experiencing a very strange and frustrating AF lock issue on the Canon EOS R6 Mark II. This specific behavior is causing me to miss critical shutter moments during my shoots.Summary of the Problem:Settings: I have "Servo AF" assigned to the...
Canon R5 ii viewfinder working. Screen working for playback but not for shooting. Screen/viewfinder display set to auto2. Was working fine. I must have touched a button (on the body, not in the menu) but now don't know how to get the display back ...
My Canon digital Rebel XTi will no longer connect to my laptop as a drive. It used to show up as a drive named. If I remove the memory card and attach it to a card reader everything works fine. I would prefer to not have to use a card reader if the c...
R8: I'd like to ask about using Canon's new flash hot shoe contact with the R8. My understanding was that the R8 can ONLY take the new hot shoe style flashes and that you needed an adapter to use an old "traditional 5 pin" flash. Well, I used a 430...
I got my first major pro wrestling gig. I’ll be shooting from the hard cam area. Where the cameras are setup away from the ring. I asked ChatGPT to give me some consensus good settings for some nice clear photos. I’m using an R6 with a Tamron 70-200m...
| Subject | Author | Posted |
| 05-19-2026 01:06 PM | ||
| 05-14-2026 07:24 PM | ||
| 04-22-2026 11:08 AM | ||
| 12-18-2025 01:20 PM | ||
| 12-14-2025 10:25 PM |
