Canon r10 frequently failing to find focal point?
mrPickles
I've had a Canon r10 for 2 years or so now and frequently, since I got it, it has trouble finding focus. One time it'll be able to find a single bird in flight, and others it can't focus on a cardboard box sitting on a well lit table. It struggles the most in spot focus, but all are similarly terrible.
My father-in-law was sitting 10' from me, completely still, in a decently lit room, and it would not focus on his face. It just zooms through the autofocus range and settles on the red square. You can see the behavior in this video where I'm trying to focus on different things around the room... And it can't get any of these. I have cleaned the contacts for the lens and camera. Tried different lenses, including ef lenses with an adapter, different sd cards, and every autofocus setting I could find.
Pertinent settings:
AF operation: One shot (tried servo but fails in the same way)
AF area: spot is the worst. Whole area finds a focal point almost every time, but obviously is not always the focal point I want. All the other AF areas behave very similarly to spot, though find it slightly more often.
Subject tracking: tried on and off. Seemingly no difference. Same with subject detection, eye detection
AF-assist beam firing: currently on, but also toggled with seemingly no difference.
Lens drive when AF impossible: On
I initially made excuses thinking it was always not well lit enough, or subject moving or something, but I honestly think I just got a lemon. Any suggestions on other settings I might not have tried? I'm going on a bit trip tomorrow and sadly probably going to leave it behind and take my old T2i because at least it's reliable.
mrPickles
It was the firmware. I updated to 1.6 and the problem is gone. I'm guessing the problem was far more widespread than what they said in their release notes because I had the issue regardless of Highlight Tone priority and drive mode.
Fixes an issue, in which when performing shooting in high-speed continuous shooting + mode with the [Highlight Tone Priority] option set to [ON], focus may not be achieved when certain ISO speed settings are used..
5 REPLIES 5
kvbarkley
VIP
VIP
What lens?
The kit lens, RF-S18-150mm F3.5-6.3. But I rented an RF lens and had the same behavior. My old EF lenses with a converter behave the same way on this camera.
Waddizzle
I need more information about your AF settings.  Shooting indoors can be problematic at times because of light flicker from artificial lighting.
Do experience the issue when shooting in Intelligent Auto, the green square?
The Spot AF Mode doesn’t do what people assume it should.  You need to have a pretty steady hand or use a tripod.
Do use any lens filters?
It doesn't seem to be affected by light or contrast. I've had this issue shooting outdoors in full sun, trying to capture a flower that had great contrast against it's background.
I guess I always default to AV or TV and haven't tried auto. Will try that.
I've always shot spot in the past and never had an issue aside from a flower bobbing in the wind at very low apertures or something. The only focal mode that doesn't give me any issues is whole area, but that has missed the focal point so many times, I had to turn it off.
No lens filter.
mrPickles
Holiday
