09-29-2023 03:13 PM
Hi all. I'm at my witts end with these cameras. Im a full time wedding photographer and I have 3 R5's. I am getting the err20 on ALL of them. And they all are only around a year old. They have nowhere near the amount of shutter clicks that should cause the shutters to fail. It seems almost as if they're getting stuck. Its weird.
I only use canon RF lenses, only use canon batteries, do not use any sort of 3rd party anything on them. I have also updated all firmware on the cameras and lenses. Still, Im getting the errors.
I have been a lifelong canon user. From rebels to all of the 5D ones and now the R5s. I absolutely love these cameras but I cannot trust these cameras at this point. I had to rent a camera at my last wedding. Which is ridiculous since I spent close to 12k on these.
Any suggestions? I guess I will have to send them in but after spending this money on these and them ALL failing within the first year is absolutely unacceptable.
09-29-2023 04:19 PM - edited 09-29-2023 04:21 PM
Error 20 is a mechanical issue with either the shutter or the mirror, but it is extremely unlikely that you would get the same error message with three such bodies, so let's look for a commonality elsewhere. It would also be interesting to know if you have been experiencing this error with different lenses, or if it is one lens what that is please. Also, what SD cards are you using please?
09-29-2023 04:39 PM
Hi Trevor -
I only use two lenses - the RF 24-70 and the RF 70-200. It happens with both lenses.
For cards I use dual memory slots. For my SD slot I use sandisk extreme pro UHS-II, and for the Cf express slot I use Sandisk extreme pro as well. Both 128GB.
For a while I could do the whole turn off the camera, remove the battery and turn them back on and it would work. But now they don’t work at all.
I don’t abuse my cameras and take very very good care of them. Which is why I find this so frustrating.
09-29-2023 07:15 PM
Sorry to hear about your issues. I would send at least one camera body to Canon for a checkup.
I agree with Trevor. It is unusual for three cameras to have the same failure mode at the same time. There could be some common denominator that is causing the issue.
The most obvious commonality is their environment. Are they getting dirty inside of the lens mount? Use a rocket blower to puff them out just to be sure. Ditto for the lenses.
This is an unusual issue. The first step is to send at least one body to Canon for inspection.
09-29-2023 07:30 PM
Are you using Canon OEM batteries or third party?
Any non-Canon attachments?
09-29-2023 07:37 PM - edited 09-29-2023 07:46 PM
My original post says only canon batteries (yes they’re oem) and NO third party anything attached. I only buy canon.
The cameras are kept immaculate. I shoot mostly indoor, and outdoor stuff is never around sand or dirt. I had the 5D Mark II, Mark III and Mark IV cameras for 5 or so years each and shot much more than I do now and never had a shutter issue. Never had any issues with that line.
I have colleagues who have the R series (R6 and R3) and they’ve had this issue as well. Though they’re still at the point where if they turn off the camera and remove the battery they can then continue to shoot. Mine did that for a while and now it’s to the point when I turn it back on it immediately has the error on one of them and the other two if I take one shot it shows up.
I'm beyond frustrated as a loyal canon customer for 20 or so years. I’ve spent tens of thousands on equipment with them and this is the first time I’ve ever had any issues. And now to have to pay $499 each on cameras that are all only a little over a year old is ridiculous.
09-29-2023 07:47 PM
"And now to have to pay $499 each on cameras that are all only a little over a year old is ridiculous. "
You may not have to pay. You should initiate verbal contact with Canon and describe the situation. Don't just send them in.
09-29-2023 09:34 PM
Agree this is an unfortunate situation. Where did the $499 come from. Is this an estimate based on a repair order you created?
I'd follow John's advice. Contact support. They are always friendly and extremely helpful when I call. Canon does care. You need to talk to someone.
~R5 C (1.1.2.1), ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve Studio ~ImageClass MF644Cdw MF656Cdw ~Pixel 10 ~CarePaks Are Worth It
09-30-2023 12:11 PM - edited 09-30-2023 12:13 PM
@OakandGold wrote:Hi Trevor -
For cards I use dual memory slots. For my SD slot I use sandisk extreme pro UHS-II, and for the Cf express slot I use Sandisk extreme pro as well. Both 128GB.For a while I could do the whole turn off the camera, remove the battery and turn them back on and it would work. But now they don’t work at all.
This is just a wild guess. Since it happens to 3 cameras in the same environment, could it be a strong electromagnetic field. Are there any devices nearby that contain radio transmitters, magnets, or transformers. If you are not using any of the radio transmitters built into the cameras, maybe put them in airplane mode.
I do not known of any way to attach an electrical ground to the cameras or shield them.
I have seen electronics misbehave when there is a powerful transmitter nearby.
09-30-2023 12:41 PM
I does indeed sound environmental. Are all the weddings in the same or in nearby venues? In that case, a road trip may be in order just to see if the cameras continue to exhibit the issues at different locations further away.
