EOS DSLR & Mirrorless Cameras
Resolved! T8i failure to connect. No Wi-fi Access point?
I have a T8i, and if this is not the right place to post this, just direct to the right one. Last night we had a major storm and we lost power. As a result, my home Wi-fi router went out. It gave me a chance to test something. If I'm out in the middl...
stevet1 by Elite
  • 3858 Views
  • 5 replies
USB-C power for R8 isn't working
I have two Canon R8s and recently purchased a monitor and a Neewer PS050E V-Mount battery to power the monitor and camera. I have run into an issue where power isn't being delivered to the camera via USB-C. This happens on both camera bodies.The Neew...
EOS R10 - connection error
I've suddenly stopped being able to import pictures from my camera to my phone.  It's connected but when it tries connecting to wifi it tries for a long time then stops with the message 'could not connect to wifi check camera settings'....and the cam...
KarenS22 by Apprentice
  • 3283 Views
  • 2 replies
Moiré pattern with EOS R6 Mark II.
I've just photographed my second wedding on my new R6Mk2 and I was surprised to see that a few of the images contained moiré pattern, I've been a Canon shooter for over twenty years starting with the D60 and I've never seen it before. Is there anythi...
adam461 by Contributor
  • 4811 Views
  • 3 replies
5D Mark IV: Tether and interval timer
Hi! Trying to see of there is a way or workaround to what I want to do. Camera is the 5D Mark IV Aa self portrait artist I have found the easiest/best way for me is to use the interval timer. I can set up to do 30 or so images then go and check. Of c...
Resolved! EOS RP flash sync issues beyond 1/180
Hi all,   I was recently contacted by an IG eos RP user regarding this issue and I tested it out today, and realized I too have this issue in my RP.  I was taking pictures with off camera and on-camera (external) flash, and any image above the 1/180 ...
Crey23 by Contributor
  • 39362 Views
  • 20 replies
EOS R1 - locking up
I am a back-button focus user:  the AF-ON button and the AE Lock button are programmed to start autofocus;  Half-press of the shutter button is programmed to only meter; and the Smart Controller and the Multi-controller are disabled.  As default, I a...
KenC2 by Contributor
  • 4996 Views
  • 4 replies
