08-02-2022 11:09 PM
I can't get my R3 to use any shutter above 1/8000. I am using an EF adapter with a Canon 35mm F2.0 lens. I have the camera set to electronic shutter and I have set the maximum shutter speed to 1/64000 in the menus. I have tried in both manual and Tv mode and I can't get it to work. I have tried at various aperture setting with no luck. I have done a Google search without any satisfactory results. I hope someone knows the answer and thanks for all your help.
08-02-2022 11:20 PM - edited 08-02-2022 11:23 PM
Can you please confirm what firmware version you are using?
You may be limited by the fact you are using EF lenses and an adapter, rather that native RF lenses. I have not seen any reference to tthisability for legacy lenses.
11-23-2022 07:02 AM
Please check your "Same expo. for new aperture" in orange menu.
Shutter speed will be limited when this function set with Tv/ISO and Tv
08-20-2023 04:05 PM
It’s crazy how many functions are limited by settings/choices that you don’t correlate having a impact. Like silent shutter. When that’s on you can’t use a flash on camera. Thank you. I use that setting you referenced for Timelapse’s- exposure adjustment
08-20-2023 07:28 PM
Disable light flicker.
08-08-2024 08:48 PM
I just received my R3 last week. I found I can achieve those higher shutter speeds with the electronic shutter, but only in Manual or Tv modes
