04-16-2022 05:52 PM - edited 04-16-2022 06:15 PM
To begin I have a CANON REBEL T7 with a 24-70 mm CANON lens.
I have taken quite a bit of time scouring the internet for the do's and don't of photography. All my images are RAW files and I shoot in Manual mode and use the auto focus mode (which I feel like is what the issue is)
ISO is 100 f/28 1/320 I think I was set at AL SERVO
I point the red dot on the face and then I open the files and some/most of the pictures come out "annoyling" grainy. I don't know what to do!
Is the AF Point Selection just no good? I heard the center one is the best to use, but the face or subject I want in focus isn't always smack dab in the center.
Is it the distance I am shooting from? If so could someone explain to me in simple terms what and how the best shooting distance is determined?
Is my camera no bueno and its just not capable sometimes of getting crisp shots?
Do I need to use manual focus and if so HOW> it seems like it would make photo taking take forever trying to make sure you get the right focus?
04-17-2022 06:44 PM
EF 24-70mm f/2.8L II USM is my lens
04-17-2022 07:05 PM
This has been very informative as I have a T7. Thanks for a valid question and to those who replied with the information. Lots to learn.
04-18-2022 05:53 PM
I use the eye level viewfinder 99% of the time. But I suppose it is a personal preference.
04-18-2022 06:16 PM
Sam this shot is great. I did a bit of exposure editing and unsharp mask in PS. I also did a WB adjustment.
It would be even better if you had u/l the Raw file. A jpg gets compressed and data discarded that can never be used to help edit. This probably means there isn't anything wrong with the camera/lens so you need check your technique.
04-18-2022 08:53 PM - edited 04-18-2022 10:13 PM
Looking at the photos, the issue, to me, seems to be in focus. Exposure may be better or worse, but the focus in some images is not right. You are using a good lens, and the shots I have seen do not suggest a shutter speed that would encourage camera shake, to I feel it is on what and how your camera is focusing.
I realize that you are using centre point focus, but the issue can be that even with setting a focus point correctly, as the camera is repositioned to compose or track the subject, the shutter button may lose track and focus on a different location. The solution I am suggesting exploring takes the focus function away from the shutter and assigns to to the AF-On button at the back of the camera. Thus you focus with that, it locks and then you can recompose and press the shutter button when ready to capture your image without risk of losing focus.
Here are a couple of You Tube videos on how to set that up and why you would want to do so:
See: https://www.youtube.com/watch?v=2AXUzslHnRc from Canon Aus.
04-18-2022 09:03 PM
Hi Trevor. Unfortunately this forum software doesn't number responses. Look at my response where I posted the two dog photos. You can see that the OP used single point One Shot AF. The one focus point is shown as a red square.
04-18-2022 09:08 PM - edited 04-18-2022 09:51 PM
Hi John, thanks for that. 🙂 Yes it is confusing and very frustrating!
I have expanded on my post to include what I hope may be of significant help - i.e. the use of BBF and the AE-L features to make sure that critical parts of the subject are in focus and the image is correctly exposed.
My concern is that in using the shutter button to hold focus that this could be an issue in focus shift if the finger relaxes a bit, or the subject moves. I thought it was worth a try and it is a well-established method.
04-18-2022 10:01 PM
In the dog images the focus point is on the dog for both images. In One Shot AF the shutter won't fire unless focus is confirmed.
The shutter speed is almost twice the focal length- 1/40 second/24mm. Should be enough for normal handholding stability.
That's why I'm thinking severe hand holding shake or a potential camera problem.
That's why i recommended the OP see about a tripod to run a test.
A number of the other images also so single point One Shot AF with focus point in the same location on in and out of focus images.
04-18-2022 10:31 PM - edited 04-18-2022 10:31 PM
First I have been driven mad by not finding posts that are not in chronological order, as they are slotted with the posts to which they reply, as opposed to the struct chronology of the old interface. Further made worse by having to keep clicking to see more...
I certainly agree that shooting with a tripod is a good idea. In the dog images you mention - that I finally found - the top image seems to have the eye more in focus but when I look at the focus point, it is on the nose (rather than the eye). Since the face of the dog is turned to our left, that puts the eye in roughly the same focal place as that point on the nose, which likely saves that shot.
On the other hand the lower photo has the face more direct and the focus point is still not on the eye, but this time the DoF does not allow for that degree of depth.
So, to me, the issues are:
1. Is the camera operating properly?
2. Is Sam focusing on the right spot: the eye - I suspect not, and that is an issue.
3. If not, why not? If she intends to focus on the dog's eye, has the focus point shifted during composition?
So, I am not at odds with you there, but offering a suggestion to investigate a solution that I know works well for accurately shooting a wide range of subject.
In the end, I think we are all still feeling our way with this puzzle! 🤔
