05-12-2022 12:28 PM
I was noticing on a recent sports event that my R6 paired with my EF 24-105 f/4 (vello adapter) showed significant chromatic abberation (I think) -- see attached image. The R6 settings for abberration are ON. I've not seen this before. Anyone experience this ?
05-12-2022 01:04 PM
Does the camera know it has an EF lens? Is the Vello adapter masking the lens type?
05-12-2022 01:27 PM
R6 reads the lens model correctly in the menu settings
05-12-2022 02:55 PM - edited 05-12-2022 02:56 PM
What were your settings for taking this shot, esp. shutter speed?
Have you repeated this by shooting other objects that are not moving?
05-12-2022 04:39 PM
It seems t be limited to the very “white” (maybe blown out) regions of your subject. Could be a result of your software?
CA is generally all around.
Can you post a link to file out of camera? Preferably RAW.
05-12-2022 05:59 PM
The posted image is only 998 x 691 in size. This could explain part of the issue. Did you capture the original as RAW and apply any lens correction?
05-12-2022 06:27 PM
1/1600 s f/4, ISO 160, Focal length 60mm
I've seen on a few other pics but I shot ~ 7000 that day and most are ok.
The image I attached is a screen shot. I'll attach a jpeg
05-12-2022 06:29 PM
05-12-2022 06:35 PM
I'm using LightRoom and both the RAW image and post processed jpg show the abberation.
05-12-2022 07:47 PM
@OnShotImages wrote:I'm using LightRoom and both the RAW image and post processed jpg show the abberation.
Thanks, for the update.
Remember. The camera only records what the lens sees. CA is created in the lens, not the camera. Again. If you are shooting RAW, are yo applying any lens correction?
