R5 and RF 24-70 f2.8 IS USM chromatic aberration in RAW
NSphotographer
I am experiencing significant CA distortion when taking landscape photos into the sun. With Digital Lens Optimizer applied the income correction is only effective in JPEGS. RAW photos are not corrected. Is this the expected outcome?
Canon setup: R5, RF24-70 IS USM, POLARIZER.
ISO 50, 70mm, f6.3, 1/100s RAW, 42.6MB
Thanks
4 REPLIES 4
Please start by reviewing this KB article.  According to this article, CA cannot be corrected on JPGs, only RAW.  Are you certain you have the lens profile downloaded for the lens?
Using the Digital Lens Optimizer in Digital Photo Professional Ver.4.x (canon.com)
Tronhard
VIP
VIP
What software are you using to process your RAW images?
There are actually two types of Chromatic Abberation: Lineal and Transverse.  In digital sensors, axial CA results in the red and blue planes being defocused (assuming that the green plane is in focus), which is relatively difficult to remedy in post-processing, while transverse CA results in the red, green, and blue planes being at different magnifications.
It is important that your post-processing software had the correct lens correction algorithms.  Generally programs like Adobe Photoshop and Lightroom, will have these Transverse corrections available and usually do the corrections as the RAW images are loaded.   In-camera lens corrections for Transverse Aberrations are done to JPGs only.
cheers, TREVOR
Peter
The part seems to be in clipped highlights.
Digital photography introduced some new types of color fringes, that are not lens chromatic aberration. They are frequently confused with TCA and unfortunately they occur often mixed with TCA. These effects might be visible as purple or blue fringes and are visible around overexposed areas in most cases.
https://hugin.sourceforge.io/docs/manual/Chromatic_aberration.html
The part of the boat that is not in the clipped area has TCA that is easy to correct.
Good article. I'm not sure I totally understand what CA and DLO are--but I do have them enabled in my camera.
I downloaded the lens data and played with the sliders. Honestly, I can't tell any difference.
As I see Lightroom Classic has my lens annotated in the Lens Correction panel, I guess it auto loads the lens data.
Thanks.
