05-12-2022 12:28 PM
I was noticing on a recent sports event that my R6 paired with my EF 24-105 f/4 (vello adapter) showed significant chromatic abberation (I think) -- see attached image. The R6 settings for abberration are ON. I've not seen this before. Anyone experience this ?
05-12-2022 07:49 PM
@OnShotImages wrote:
This image looks pretty good at actual size. Are you using any lens filters?
05-12-2022 07:53 PM
Can you upload the RAW file to Dropbox or One Drive?
05-12-2022 08:37 PM
If it was simple diffraction, I would expect to see the halo effect around the person, or at least on the brightest areas, but I am intrigued that is found only on the cyclist's trailing edge...
05-12-2022 10:02 PM
No filters used. Appreciate everyone's attention to the issue.
05-12-2022 10:03 PM
Yes lens correction is applied in LR. Thanks for clarifying the source of CA - I'm not technical enough about cameras and such.
05-12-2022 10:09 PM
05-13-2022 06:34 AM - edited 05-13-2022 09:28 AM
Looks like you need to authorize access. I sent request.
05-13-2022 09:36 AM - edited 05-13-2022 09:46 AM
I think what you are seeing is "blooming".
DPP reports the RGB values of the area around the edge of the helmet and shirt as 255,255,255 (i.e. locally blown out).
05-13-2022 01:02 PM
"Are you using any lens filters?"
If you are discard it. Secondly, get a Canon adapter. But that could actually be what the camera and lens saw if it was a hot day. Heat wave rising from the rider.
05-13-2022 01:48 PM
Thanks for investigating this...I need to up my tech knowledge!
