02-06-2015 06:04 PM
02-06-2015 08:32 PM
02-06-2015 08:32 PM
I think there is no exposure lock on Manual Mode. 🙂
02-06-2015 08:37 PM
02-06-2015 09:11 PM - edited 02-06-2015 09:11 PM
Is there really an exposure lock in Manual Mode ?
02-06-2015 09:27 PM
02-06-2015 10:45 PM
@grrjr wrote:
Nope. Meter for what you are wanting to expose properly then adjust your settings to get the exposure you want. There's no lock because you are adjusting the settings based on what you are metering. There's no lock for the same reason there isn't exposure compensation in manual mode.
I wonder if that isn't a little too facile. There's no exposure lock because there's nothing to lock; you're already setting it manually. But you can't make the same argument about exposure compensation. If the camera's meter consistently misreads the brightness of the scene, it will tell you to use an erroneous setting. Exposure compensation would spare you from having to remember to make the adjustment each time.
02-08-2015 09:29 AM
"There's no exposure lock because there's nothing to lock; ..."
Yes sir! ![]()
In a sense of the word, it is "locked". It will not change unless you change it. Right?
