EOS DSLR & Mirrorless Cameras
Resolved! EOS R6 Mark II One Shot AF Focus Hunt
Has anyone else had this issue with the R6 MK II? Recently purchased a RF 35mm 1.8 STM.I am having a problem when used with my R6 MK II.When using the Av mode - One Shot...regardless of one Spot AF, 1 Point AF or Expanded it does not lock onto the se...
xzebra by Contributor
  • 253 Views
  • 9 replies
EOS R7 Body or lens damage at 0-5°F?
I have a couple hours tomorrow and wanted to do some birding, but the real temperature is supposed to be between 0-5°F here in Michigan. I’ve shot no problem a few times at 15-30° but am I risking any actual body damage going out with it at the lower...
dajana1 by Apprentice
  • 184 Views
  • 6 replies
Factory Reset EOS R6 Mark II
I have a lot of settings / custom settings in my current R6 MK II, but was suggested to possibly do a factory reset due to some focusing issues I have had.  Is there any possible way to save the settings before proceeding?    https://community.usa.ca...
  • 99 Views
EOS 1300D Lithium Cell Specs
Hi, I purchased a dead 1300D . The issue was the internal cell battery on the power board. I’ve cleaned the corrosion, repaired the damage and some other issues. The camera is like new and inside and out. My issue is what is the cell battery ? I have...
Resolved! EOS R7 - Can't Find Aspect Markers
Hello! I recently upgraded from my Canon r50 to an r7 for some freelance sports videography. I've been loving the camera but one issue I have is that I'm having a hard time finding the Aspect Marker setting. I used it on my r50 when filming video I k...
Resolved! Eos 250d not compatible with godox flash
I was gifted a TT520ii flash for my canon eos 250d dslr camera, but in setting it says it’s not compatible and I was wondering what setup or adapter I need to get to make it work? Or if I’m better off just getting a whole different flash?
EOS 90D UHS-II SD card compatibility
Does the EOS 90D have the second row of pins needed for utilizing the extra speed of a UHS-II SD card? Various sources are contradictory on this answer. I'm not looking for an answer of, it will accept a UHS-II card, but whether the body has the requ...
R6 Mk II Missing only todays photos
I am a real estate photographer and I shoot several properties a day both photo and video. I cannot explain this issue. I had two shoots today, morning and afternoon. 0 issues at either, R6 Mk II I've been using a while now worked perfectly as usual,...
jspfpv by Apprentice
  • 168 Views
  • 4 replies
  • 4 likes
