01-22-2026 03:46 PM
I was gifted a TT520ii flash for my canon eos 250d dslr camera, but in setting it says it’s not compatible and I was wondering what setup or adapter I need to get to make it work? Or if I’m better off just getting a whole different flash?
01-22-2026 06:18 PM
The EOS 250D lacks the center pin on the hot shoe that’s why it doesn’t work. So it doesn’t have a standard hot shoe. Instead it has a proprietary hot shoe for Canon’s own EX series speedlites. So you’ll need a Canon speedlite ending in EX to work. Or the Canon EL-1 or EL-100 as compatible flash units. Other EL series speedlites are INCOMPATIBLE and only work on certain EOS R series cameras.
01-22-2026 05:33 PM
Laylharvath,
Your manual says that the 250D is compatible with the EL and EX series Speedlights.
The EOS Magazine had a directory of these Speedlights here:
You can down through the list and do Google searches on each one to see if it will meet your needs and what you can afford.
Steve Thomas
01-22-2026 05:57 PM - edited 01-22-2026 05:59 PM
Godox says your flash works with any camera with a standard hotshoe. That's what it has. If you want a flash that is compatible in all ways with a camera with additional contacts, you need a flash made to work with that camera.
Unless a flash is made to be compatible with Canon (or Nikon or Sony) digital cameras, it's not. If you want a flash that integrates fully with a camera's features and functions, you have to buy one. Even then, an aftermarket brand, from Godox or another maker, will not be 100% guaranteed by Canon to work to do "everything" a Canon will. The flash maker can't make that absolute guarantee either. Canon absolves itself of this in their camera manuals....as do other camera and flash makers.
01-22-2026 06:18 PM
