08-16-2024
08:36 PM
10:32 PM
Tiffany
Hello -
I have a back button set to focus on faces. The image shown here (a jpg capture of the RAW file) had no faces and My R5 therefore did not focus on anything. Is this the default when no face is found? I was too dumb to practice and learn about this before my trip.
08-16-2024 09:52 PM - edited 08-17-2024 12:07 AM
That is not my experience. I have face/eye detect pretty well always enabled and even when there is no face to detect, I still get a focus. I too use BBF, single point centred, with servo and with face/eye tracking. I point at my desired point of focus, tap the AF-ON and recompose to shoot. I never seem to have a problem, I must admit.
Still, I wonder if you are not using single-point centred if you would get better results. Without that, if the focus cannot find a face across the frame then it would revert to looking for the closest point, or with the best contrast. So, by forcing single point, I can force that specifically.
Failing that I have Face/eye animal plus all the rest set to C1, while C2 is the same but with humans.
08-16-2024 09:07 PM
mangurian,
I'd say that if you are taking pictures that don't have any faces, then disable your face detection in your settings. Just use single point.
You did a fairly reasonable job anyway.
PS: If you want to insert a picture in your post, click on the little icon that looks like a camera.
Steve Thomas
08-16-2024 09:17 PM
