EOS R5 - Light Source exif value no longer used?
DaveKennard
Checking the EXIF on images from my Canon R5 there doesn't seem to be a value for 'LightSource'. Just wanted to check this is correct, and if there is an alternative, e.g. if the same value is now stored somewhere in the makernotes instead?
@DaveKennard wrote:
Thanks, so is LightSource used for flash only? I presume it is only certain flash models that cause it to be added then? I just took a couple of test shots with my Canon MT-24EX in manual and ETTL and the LightSource was not present in the EXIF on either image.
You might look at the various white balance values reported in the metadata.
While lightsource is in the exif standard, I do not see it in any files from my Canon cameras.
EXIF LightSource Values
Value LightSource Value LightSource Value LightSource
0 = Unknown 12 = Daylight Fluorescent 20 = D55
1 = Daylight 13 = Day White Fluorescent 21 = D65
2 = Fluorescent 14 = Cool White Fluorescent 22 = D75
3 = Tungsten (Incandescent) 15 = White Fluorescent 23 = D50
4 = Flash 16 = Warm White Fluorescent 24 = ISO Studio Tungsten
9 = Fine Weather 17 = Standard Light A 255 = Other
10 = Cloudy 18 = Standard Light B
11 = Shade 19 = Standard Light C
File:Other FileName IMG_3524.CR3
MakerNotes:Image WhiteBalance Auto (ambience priority)
MakerNotes:Image WhiteBalanceRed 0
MakerNotes:Image WhiteBalanceBlue 0
MakerNotes:Camera MeasuredRGGB 535 1024 1024 544
MakerNotes:Camera WB_RGGBLevelsAsShot 1856 1024 1024 2362
MakerNotes:Camera WB_RGGBLevelsAuto 1853 1024 1024 2356
MakerNotes:Camera WB_RGGBLevelsMeasured 1853 1024 1024 2356
MakerNotes:Camera WB_RGGBLevelsDaylight 1975 1024 1024 1886
MakerNotes:Camera WB_RGGBLevelsShade 2305 1024 1024 1613
MakerNotes:Camera WB_RGGBLevelsCloudy 2131 1024 1024 1753
MakerNotes:Camera WB_RGGBLevelsTungsten 1369 1024 1024 2929
MakerNotes:Camera WB_RGGBLevelsFluorescent 1689 1024 1024 2796
MakerNotes:Camera WB_RGGBLevelsKelvin 1975 1024 1024 1886
MakerNotes:Camera WB_RGGBLevelsFlash 2212 1024 1024 1683
Composite:Camera WB_RGGBLevels 1856 1024 1024 2362
File:Other FileName IMG_3524.JPG
Canon WhiteBalance Values
Value WhiteBalance Value WhiteBalance Value WhiteBalance
0 = Auto 8 = Shade 17 = Underwater
1 = Daylight 9 = Manual Temperature (Kelvin) 18 = Custom 3
2 = Cloudy 10 = PC Set1 19 = Custom 4
3 = Tungsten 11 = PC Set2 20 = PC Set4
4 = Fluorescent 12 = PC Set3 21 = PC Set5
5 = Flash 14 = Daylight Fluorescent 23 = Auto (ambience priority)
6 = Custom 15 = Custom 1
7 = Black & White 16 = Custom 2
If one were interested in the flash,
  • [EXIF:Camera] Flash : On, Fired
  • [MakerNotes:Camera] CanonFlashMode : External flash
  • [MakerNotes:Camera] FlashActivity : 157
  • [MakerNotes:Camera] FlashBits : E-TTL, External
  • [MakerNotes:Camera] ManualFlashOutput : n/a
  • [MakerNotes:Image] FlashExposureComp : 0
  • [MakerNotes:Image] FlashExposureLock : Off
  • [MakerNotes:Camera] WB_RGGBLevelsFlash : 2305 1024 1024 1611
  • [MakerNotes:Camera] ColorTempFlash : 7025
  • [EXIF:Image] FlashpixVersion : 0100
  • [Composite:Camera] FlashType : External
5 REPLIES 5
NatalyaP
Greetings DaveKennard,
If using a Canon flash, then the EXIF data may display the information on whether or not the flash was on when taking the picture and may provide the flash type, like if using E-TTL. We cannot guarantee EXIF data will be recorded if using a non-Canon flash or strobe, or when reading EXIF data on non-Canon software. For example, this information can be viewed when looking at the EXIF data in Digital Photo Professional.
DaveKennard
DaveKennard
Thanks for that. So a direct answer would be that yes, there is no value for LightSource. But this is not a recent change, probably it has never been supported in Canon cameras. The nearest alternative is the WhiteBalance value.
