05-08-2025
10:57 AM
03:12 PM
James_C
Checking the EXIF on images from my Canon R5 there doesn't seem to be a value for 'LightSource'. Just wanted to check this is correct, and if there is an alternative, e.g. if the same value is now stored somewhere in the makernotes instead?
05-14-2025 03:40 PM
@DaveKennard wrote:
Thanks, so is LightSource used for flash only? I presume it is only certain flash models that cause it to be added then? I just took a couple of test shots with my Canon MT-24EX in manual and ETTL and the LightSource was not present in the EXIF on either image.
You might look at the various white balance values reported in the metadata.
While lightsource is in the exif standard, I do not see it in any files from my Canon cameras.
Value LightSource Value LightSource Value LightSource 0 = Unknown 12 = Daylight Fluorescent 20 = D55 1 = Daylight 13 = Day White Fluorescent 21 = D65 2 = Fluorescent 14 = Cool White Fluorescent 22 = D75 3 = Tungsten (Incandescent) 15 = White Fluorescent 23 = D50 4 = Flash 16 = Warm White Fluorescent 24 = ISO Studio Tungsten 9 = Fine Weather 17 = Standard Light A 255 = Other 10 = Cloudy 18 = Standard Light B 11 = Shade 19 = Standard Light C
File:Other | FileName | IMG_3524.CR3 |
MakerNotes:Image | WhiteBalance | Auto (ambience priority) |
MakerNotes:Image | WhiteBalanceRed | 0 |
MakerNotes:Image | WhiteBalanceBlue | 0 |
MakerNotes:Camera | MeasuredRGGB | 535 1024 1024 544 |
MakerNotes:Camera | WB_RGGBLevelsAsShot | 1856 1024 1024 2362 |
MakerNotes:Camera | WB_RGGBLevelsAuto | 1853 1024 1024 2356 |
MakerNotes:Camera | WB_RGGBLevelsMeasured | 1853 1024 1024 2356 |
MakerNotes:Camera | WB_RGGBLevelsDaylight | 1975 1024 1024 1886 |
MakerNotes:Camera | WB_RGGBLevelsShade | 2305 1024 1024 1613 |
MakerNotes:Camera | WB_RGGBLevelsCloudy | 2131 1024 1024 1753 |
MakerNotes:Camera | WB_RGGBLevelsTungsten | 1369 1024 1024 2929 |
MakerNotes:Camera | WB_RGGBLevelsFluorescent | 1689 1024 1024 2796 |
MakerNotes:Camera | WB_RGGBLevelsKelvin | 1975 1024 1024 1886 |
MakerNotes:Camera | WB_RGGBLevelsFlash | 2212 1024 1024 1683 |
Composite:Camera | WB_RGGBLevels | 1856 1024 1024 2362 |
File:Other | FileName | IMG_3524.JPG |
Value WhiteBalance Value WhiteBalance Value WhiteBalance 0 = Auto 8 = Shade 17 = Underwater 1 = Daylight 9 = Manual Temperature (Kelvin) 18 = Custom 3 2 = Cloudy 10 = PC Set1 19 = Custom 4 3 = Tungsten 11 = PC Set2 20 = PC Set4 4 = Fluorescent 12 = PC Set3 21 = PC Set5 5 = Flash 14 = Daylight Fluorescent 23 = Auto (ambience priority) 6 = Custom 15 = Custom 1 7 = Black & White 16 = Custom 2
If one were interested in the flash,
05-12-2025 08:11 PM
Greetings DaveKennard,
If using a Canon flash, then the EXIF data may display the information on whether or not the flash was on when taking the picture and may provide the flash type, like if using E-TTL. We cannot guarantee EXIF data will be recorded if using a non-Canon flash or strobe, or when reading EXIF data on non-Canon software. For example, this information can be viewed when looking at the EXIF data in Digital Photo Professional.
05-14-2025 02:52 PM
05-14-2025 03:40 PM
05-14-2025 04:12 PM
05-15-2025 05:07 PM
Thanks for that. So a direct answer would be that yes, there is no value for LightSource. But this is not a recent change, probably it has never been supported in Canon cameras. The nearest alternative is the WhiteBalance value.
