02-23-2025 01:12 PM
Good morning. I'm new to the community and would love any troubleshooting suggestions for our new EOS 6D Mark II camera. The battery is fully charged and inserted correctly. Two SD sim cards inserted correctly. When the battery clicks in place a brief red light appears and disappears on the back of the camera. When I turn the power to "on" and ensure it's in auto focus mode, nothing happens. When I say nothing, there are no sounds and nothing appears on the screen. Any suggestions greatly appreciated.
02-23-2025 04:27 PM
@Stephen this is what choices we have now down below.
02-23-2025 04:30 PM
I don't see anything explicitly preventing changes, so I'll get with Chris to get to the bottom of it! Thank you for the heads up!
02-23-2025 04:32 PM
You may be right, but that's a bit restrictive. I'll talk with him about it tomorrow.
02-23-2025 04:57 PM
@stephen I don't know how recent this change was I saw a post that mentioned the inability to edit posts but I can't remember who it was from though. I don't know if only Forum Administrators such as Chris can see changes like this and not Forum Moderators. I don't know if they're completely different things in this forum. In other Forums I use Administrators and Moderators are the same thing and use the terms interchangeably. They both have the same account privileges and can lock forums when the problem has been solved or if it needs to be shut down.
02-23-2025 05:55 PM
“ Thank you for your quick response and questions.
Thank you so very much, I think we're getting somewhere!!! “
Great! I suspect that the 16GB card is a potential issue. Try it with just the 512GB card. I don’t use cards with that much storage capacity, especially for capturing only photos.
I use UHS-II V90 SD cards, 128GB. The high capacity cards are expensive. If one goes bad, it’s a significant hit to the wallet.
If you plan to store photos on the card, then I suggest you don’t. Copy your files off the card to more reliable storage like your computer.
Make sure your battery is fully charged. Always format cards inside the camera prior to first use. Let us know how it works out.
