04-21-2022 11:42 PM
So I've used external intervalometers for years with my T series and 70D bodies but having an issue with the R5. The external intervalometer works the same as previous ones but just with a different end. I can set up a run fine, like 4 second shots with a 5 second interval and the external intervalometer seems happy with everything and goes about it's program when I click Start.
The problem is the first exposure opens the shutter but after the 4 seconds isn't ending the exposure and closing the shutter. The intervalometer goes along it's program unaware the camera never ended that first shot.
Best I'm finding on forums and such in searches is that MAYBE I have a bad (brand new) intervalometer. Suppose that could be it but wanted to ask if anyone else has run into this behavior before. TIA!
04-26-2022 09:08 AM
Just wanted to update this post that the first intervalometer must have either been faulty or isn't compatible with the R5 like it says it is on Amazon.
However, this intervalometer worked exactly as it should for me:
https://www.amazon.com/gp/product/B01MR86TMN/
04-22-2022 12:10 AM
Is there a particular reason you did not use the built-in Interval Timer feature of the R5, as shown on P244 of the manual?
04-22-2022 10:17 AM
I should have included that in my original post. I know the R5 has a (bad) built in intervalometer. Pretty embarrassing that the camera can shoot 12 or 20 fps but needs 3-4 seconds between interval shots or it gets confused. A 3-4 second gap is pretty bad for star trails and shouldn't be necessary so that's why I bought an external one that says it is compatible with the R5 specifically.
04-22-2022 01:04 PM
Your camera is set to Bulb?
04-22-2022 01:18 PM
Yeah and all NR and nanny stuff set to Off as well. One Shot AF and Single, no burst shooting.
04-22-2022 01:20 PM
And manual focus?
04-22-2022 01:41 PM
Yes, prefocus to infinity in AF then switch to MF.
04-22-2022 01:45 PM
That’s exactly how I do it with my 1D X III (except 12 secs vs 4) and 1 sec between. May be a problem with intervalometer.
04-22-2022 01:49 PM
I guess so. Mainly was wondering if anyone specifically had used any of these third party external intervalometers with a Canon R5 successfully before I bought a replacement.
This is the one I bought btw: https://www.amazon.com/gp/product/B06XBXWL97/
04-22-2022 01:57 PM
See this image
this timer has a unique timing. If you want a four second exposure and a 1 second gap you set the interval at 5 seconds. See if that resolves your issue.
