Banding in shots under led lights???
jayjjj1955
 I did a shoot last night with my EOS R of a dance performance. 12,800 ISO with a 70-300 Canon lens. In almost all of the vertical images and many of the horizontal images I got what I will call "banding lines" in the shot. It was LED theatrical lighting. Why? Can it be fixed in post?
jrhoffman75
Discussion about flicker with electronic shutter and mechanical shutter on EOS R.
https://www.fredmiranda.com/forum/topic/1580249/0
5 REPLIES 5
Ray-uk
Whiz
It's very likely the lighting was switching on and off, too rapid for you to see it but the camera could.
Can you fix it in post ....... almost certainly not.
rs-eos
What was your shutter speed? The dark areas could be due to flicker of the lights.
Agreed that it may be very difficult to fix in post.  Did you capture in RAW? If so you could try making a mask/selection defining the dark areas, then raise exposure.  But that seems like a long shot.
Ricky
jrhoffman75
Yep. This is indeed the cause of the problem. Many Thanks
The LED lights in conjunction with silent/electronic shutter is the cause of the problem. fixing in PS is not something I am even going to attempt.
