08-29-2016 09:51 PM - edited 01-19-2017 07:39 PM
08-31-2016 06:19 AM - edited 08-31-2016 08:56 AM
@Bannach wrote:I thank the friends who are anxious to help me in the sense of find out why the Serial my lenses do not appear the Exif.
After a more thorough search, I found that the serial lens is inserted manually in the camera settings, however my EOS - 5D Mark II, does not offer this function and do not know if have any further update (firmaVer) I'm using version 2.0. 9.PrScn follows, referring to the serial number input mode (this refers to EOS - 5D - Mark III)
Thank you all!
This is what I was getting at earlier. You do realize that any EF 24-105mm f/4L will look identical to the camera. Right?
08-30-2016 02:20 PM
Does it show up in DPP?
08-30-2016 03:25 PM - edited 08-30-2016 03:45 PM
@kvbarkley wrote:Does it show up in DPP?
If it does, I can't find it. But it does show in Irfanview. Go figure.
Well forget that. I just checked the lens, and the serial number reported by Irfanview is wrong.
08-30-2016 03:32 PM
I don't think Canon DSLRs record the lens serial number. In fact, the AFMA adjustment doesn't even distinguish between lenses with the same model number. The lens model number is entered by hand, for AFMA.
If you are seeing lens serial number in EXIF information of photos taken with Canon gear, it was most likely added in post.
08-30-2016 03:46 PM
I don't have the lens handy, so I can't check the actual serial number but EXIFTool on my Mac reports this:
ExifTool Version Number : 10.15
File Name : IMG_7718.JPG
File Size : 854 kB
Make : Canon
Camera Model Name : Canon EOS DIGITAL REBEL XS
Canon Image Type : Canon EOS DIGITAL REBEL XS
Canon Firmware Version : Firmware Version 1.0.6
Owner Name : xxxxxxx
Serial Number : 05702xxxx
Flash Metering Mode : Off
Focus Distance Lower : 1.5 m
Lens Model : EF-S15-85mm f/3.5-5.6 IS USM
Internal Serial Number : L0180193UU
Dust Removal Data : (Binary data 1024 bytes, use -b option to extract)
08-30-2016 04:05 PM
Is there an "EXIF Version" entry associated with any of that?
08-30-2016 04:12 PM
Exif Version : 0221
I was also pleased to see:
Camera Type : EOS High-end
Pretty good for an XS!
08-30-2016 04:33 PM - edited 01-19-2017 07:39 PM
08-30-2016 04:36 PM - edited 08-30-2016 04:37 PM
What was the EXIF version for both?
Does the 400 mm show a serial number?
08-30-2016 04:50 PM
I used the ExifTool 10:25 version for both tests.
I've watched the ExifTool the serial number Lens, Lens canon 70 ~ 200mm 100 ~ 400mm, 400mm, and other models.
