05-05-2022 09:35 PM - edited 05-06-2022 02:25 AM
So something weird.... Black text documents wont print from PDF in Acrobat and Word docs, as if there is some "type" problem? I say this because black from Photoshop of the SAME PDF prints 100% fine. ONLY from Acrobat and Word they dont print, or is very fuzzy or light. So obviously not an ink or cartridge or nozzle or ANY HARDWARE issue. This result has been performed countless times so far, there is zero variable in results.
Is there a way to clear this up, or a hard reset of the printer or firmware update etc? I couldnt find anything in an online search.
05-10-2022 09:36 PM
Ok so I cleaned the head one more time with hot water, there was still some black ink in there somewhere I saw... and I decided to open another new ink pack, and lo' and behold, it works now... I guess u have to be really patient and clean that things for a long time unless u have one of those hose things that can flush it right through with pressure... and I guess the ink cartridge also dried up a bit from no flow again so it seems all good now....
Glad it worked since this is a good printer and hate to throw it out just because of such a minor issue...
Thanks all you, for your patience and help.
05-09-2022 02:02 AM - edited 05-09-2022 02:03 AM
Took it out and it was dirty, more than other colors, and looked completely clean after I was done, and still same exact issue... dont tell me now I have to risk wasting another brand new ink cartridge to properly test this?
05-09-2022 06:07 AM
If there is ink in the old cartridge and it doesn’t print then the head s still plugged, regardless of how it looks.
If Deep Cleanings aren’t working I suspect you need a new head.
Nothing else I can offer.
05-09-2022 11:01 AM
Thought of one additional thing to try, to see if the cartridge the problem. Remove cartridge and use a paper towel to see if you can get ink firm the port on the bottom of the cartridge. If not maybe soak bottom of cartridge to dissolve dried pigment. Long shot, but easy to try.
05-10-2022 12:40 AM
Ok thanks...
If not, where is the best place to get the replacement ink cartridge, ebay?
05-10-2022 05:37 AM
I always buy my ink from Staples or Amazon. I only buy OEM ink. Can’t speak for eBay.
05-10-2022 08:47 PM
And what about the whole print head... do they sell just that?
05-10-2022 09:36 PM
