08-18-2015 04:47 PM
I cannot scan since downloading Windows 10. It says: You don't have the required privileges to access the specified folder Code 9,244,3
08-22-2015 06:47 AM
05-21-2018 03:25 PM
I have found the solution with new windows 10...
1. Open Settings
2. Selet "allow app to go through firewall"
3. select "change settings"
4. Select and allow "File and Printer sharing"
Action 2
1. Open settings
2. Open Virius and threat protection
3. Open Virius and threat protection settings
4. Open manage controlled folder access
5. Open allow an app through controlled folder access
6. Add this file to list to allow: C\Program Files (x86)\Canon\IJ Scan Utility\SCANUTILITY.exe
I did both and on all computers and I'm good to go! Good Luck!
05-21-2018 03:29 PM
1. Open Settings
2. Open "Firewall and network setting"
3. Selet "allow app to go through firewall"
4. select "change settings"
5. Select and allow "File and Printer sharing"
I forgot step two in previous post...
08-17-2018 10:53 PM
Many thanks bailey71. Your solution worked perfectly. I was starting to get very frustrated.
11-08-2018 01:10 PM
Worked for me too. Many thanks. I spent far too much time on this before I came across your post.
04-01-2019 11:51 AM
03-27-2020 12:53 PM
03-27-2020 12:54 PM
hi bailey...i did everything as u said here...but why do i still get the same "do not have the privileges to access the speficied folder"? please help...i've been doing this the whole day
07-07-2018 04:10 PM
baily71's solution worked the best (for me, anyway).
Thanks baily71.
09-28-2018 03:41 AM
12-29-2018 09:16 AM
