Wireless Router Does Not Prompt for Password: Canon TS9521
sthomas416
This is a Canon TS9521. Go to Manual Connection. Router appears. Select and "Connecting to..." appears. "Failed to connect error" appears with recommended fixes:
1. Check that the router is correct. VERIFIED
2. Check the entered password is correct. NO WAY TO VERIFY. DOES NOT PROMPT
3. Restart wireless router. DID THIS SEVERAL TIMES
I also Reset the printer. I tried connecting to a test router. Works fine. How can I remove all traces of this problematic router so I can enter the right password?
sthomas416
Patrick,
   That was indeed the problem. Thank you.
2 REPLIES 2
Patrick
Hi sthomas416,
The Wi-Fi network that you are attempting to connect to may have WPA3 enabled.
The PIXMA TS9520 is not compatible with WPA3.
Please change the security to WPA2 on the Wi-Fi network that you are attempting to connect your TS9520 to.
Once changed, you can then use the Manual Connect method to connect your TS9520 to your Wi-Fi:
1. Tap the Wi-Fi icon in the lower left corner of your printer's display.
2.  Tap Wi-Fi.
3.  Tap the Settings button at the bottom.
4.  Tap Wi-Fi setup.
5.  Tap Manual connect.
6.  Choose your wireless network from the list that appears.
7.  Tap "Please enter." and then enter your Wi-Fi password.
8.  When "Connected to the wireless router" appears, press OK.
sthomas416
Patrick,
