PIXMA G2400
Hi everyone .. my printer is canon PIXMA G2400 , it taking along time to start printing .what i can do to fix that issue ? Thanks
Hi, I wonder if anyone can help with the following: Symptom: print stops mid print; printer (Canon MX925) spits the paper out and states print finished; print details on PC still shows that the print is mid print. The print info on the PC then hangs ...
Good morning from UK. My Canon iP8500 Pixma has just given an error message after a paper jam = The appropriate print head is not installed.I now have 1 green followed by 5 yellow lights flashing on the on/off button. Can you suggest how to correct t...
I literally just set up my printer and had a little trouble with that, but finally got it figured out! Well, once I tried to print something I noticed that there was some misalignment with the words on the page and a streak running down the top half ...
One button in the Canon Quick Menu is not in English I think Japanese. How do I select or change to English?
Hello, I brought my daughters Canon printer home to try to troubleshoot it. It's an MG2920 with the power button and button #5 flashing alternately. Can someone advise?
I'm trying to connect a Canon iP1800 for the first time to my Mac (Mojave 10.14), but it says I need a print driver. Information on Canon's website says there is no print driver. I don't have the CD that came with the printer. Can anyone help?
I keep getting this error message: "A required file is missing or corrupted, or settings are incorrect. Try the installation again." I have reinstalled the software multiple times and I still get the same message. I'm on a MacBook Air running 10.13.4...
Hello, I brought my daughter's Canon MG2920 printer home to try to troubleshoot it. The power button (#1) and button number #5 are flashing back and forth continuously. Any ideas? Thanks!
I have an MG 2520 Pixma, and if there is more than one page, it prints the last page first. Can I somehow change this? It's driving me nuts!
Stapling function is not working. I already follow this link https://ugp01.c-ij.com/ij/webmanual/PrinterDriver/W/E400%20series/1.0/EN/PPG/dg-c_margin.html to setup, but still can't set the margin size to zero , is still have default margin, any one ...
I got the iP110, but now am wondering if I didn't understand the idea behind it. If I get a USB Type B adapter, can I connect my iPhone directly, and print from it? I need the ability to log into a website from the road (so no wifi) and print forms t...
On my Pixma TS3160........how do I select " Print using Black Ink Only " ?
I am trying to install my new cannon TS5120 printer on my Mac. I get an error message when trying to print test page of printer not connected. How do I fix this? I have the version High Sierra 10.13.6.
My printer has printed anything for NEARLY A MONTH, yet newly installed C251 ink carts are showing as half used ... why is this, and what is the solution?
| Subject | Author | Posted |
| 09-20-2026 05:36 PM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
