Desktop Inkjet Printers
G3400 error code 5B00
Hi there I see this code 5B00 is a common code across canon gear but have anyone got specific info for my model G3400 for fixing it? RegardsChris
afcchris by Apprentice
  • 3022 Views
Print head - PIXMA MX922
Black print is mostly skipped lines. Several deep cleanings do not help. New ink tanks do not help. Color prints all great. Probably need to replace print head.How do I do that??
awcurtis by Apprentice
  • 3229 Views
  • 3 replies
Driver download
Can someone help a poor dummy.  I couldnt scan once I downloaded Windows 10.  I tried removing the printer driver and reloading, but now it will not load the scanner driver. Printer and fax dowloaded OK and work, but I still cannot scan.  Any suggest...
Navyguy by Apprentice
  • 6020 Views
  • 5 replies
Resolved! MG5220 Won''tscan
After aout a year of non-scanning I can't  get it to scan, although it prints fine. I downloaded the latest drivers 5.1 but  when I try install I get a pop up saying the MG 5220 can't be used for this download. Is there some place I can go to get the...
Scanner Issues
Good day , i would like to enquire about my printer scanner combo , so im trying to scan multiple documents and everytime my Printer says do not open document Cover so it does scan but only on the platen , i have tried to change the settings at the s...
MP620B will not scan
I have a new laptop which runs Windows 10. As there is no driver for the Pixma MP620B, I installed the Windows 8.1 (64 bit) driver. Using a USB connection, I can print but cannot scan.  It appears as if my laptop will does not recognize that the prin...
Where's the Ink?
I bought a G4210 Megatank printer yesterday. Installed it. Today, March 24, 2019, the magenta tank shows half full. That is impossible since I have printed only six sheets. Anyone else seen half-full ink bottles in a new package? I will be chatting w...
canon pixma iP110
Hi there, I got a business and I use canon Pixma iP110 for events desk printer.My problem is that if I got a little time between prints (like 10sec), the printer got a long delay until it starts to print.Is there any way to fix this problem? Thanks f...
regin by Apprentice
  • 2951 Views
  • 3 replies
odd pattern of missing lines in print head test
 This is a print head test pattern from a Pixma MG5520. The top half of every other column of PGBK is missing lines. The other colors were OK. The stuff in the Cyan color print test is just from gunk on the glass of the scanner bed. I already tried r...
PicFlip by Apprentice
  • 6343 Views
  • 3 replies
TS9020 leaving abrasive marks on printed discs.
I just received my TS9020 and I'm getting some abrasive scratch marks on the printed side of printable discs.  This is what I bought it for and I don't need fresh scratches on the discs.  Is the printer defective or is there something I can do?
AekaGSR by Apprentice
  • 2944 Views
  • 5 replies
