G3411 Magenta and Yellow colors are not printing
I have the Canon G3411 printer. And when I nozzle check, I have this. I tried all utilities in the web remote UI of this printer. But none of them helped.
I have been scanning the forum and it seems that there are some 920 owners out there that are having the same problems as I am but there seems to be no true resolutions to the problem. Problem: I want to print on plain paper from a PDF that is two p...
says the absorber is nearly full but how do i correct this please
Hello. Today I tried to print out a 5x7 photo from my iPhone 16. I used the canon print app and made sure that I had the settings for paper size changed to 5x7 and that it was a photo on glossy paper. And this is the result. Around 3/4 inch on to...
I inadvertently replaced a cartridge with a "remanufactured" cartridge & my printer won't work at all now. The error code "7700" appears.Is there anything I can do ?? I thought of removing the cartridge, but am unable to do so.
I just refilled the three colored reservoirs on my G7020. Blue and yellow print fine (as does black), but red doesn't print even though the reservoir is full. Figuring the nozzle was probably clogged, I tried Nozzle Check, but when I clicked on it, I...
How do I increase the contrast of photos printed from my Mac desktop (Sequoia 15.5) on my TS 8220 printer?
Hello! I have a PIXMA MG7720 AIRPRINT ON MAC and am trying to print a photo from my iMac to my printer. The photo tray is loaded with 4x6 photo paper and I've set the settings to print from that tray. My file is also 4x6 but when I go to print it, th...
Hi Canon Community,I purchased a PIXMA TS3722 Wireless All-in-One Printer with Scanner and Copier from Walmart in September 2024. Unfortunately, it had persistent paper jam issues, so I replaced it with the same model in January 2025, also from Walma...
when I turn it on the only thing on the screen is a zero that keeps moving up and down on the little screen
My printer suddenly displayed this code 1403 after I was printing, copying and scanning some documents. It says it has the wrong print head and the screen will not let me go to menu. I have taken the print head out and cleaned it but it still has the...
Hi, my canon pixma 3010 is not priniting black print properly. I have done deep cleaining, ink flush and printer head alignment multiple times, however, no improvement. Kindly provide the troubleshooting steps if any one is aware of it
G3060 printer faulty from the start; falsely described as "fine art printer." It is not. Help! I purchased the printer a while ago, but it's gotten little use as it has continual problems. I've called tech support numerous times but they can't resolv...
I just moved to Europe. Is there compatible ink that I can purchase in Europe?
| Subject | Author | Posted |
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM | ||
| 12-27-2025 03:38 PM |
