pixma mx490
when setting up fax on this printer what is the unit name to be registered
My 2-years-old TS5050 makes a grinding noise when printing. Is there anything I can try or should I just live with it until it stops working? Any advice appreciated.
Tonight I went to check cartridges with my printer on and the power to the printer turned off and I can't get the power switch to turn back on. What has happened? It has been a faithful printer for a couple of years now.
I have a canon mg5400. Error message states the printer is not connected. But I have checked the wireless connection and it is connected. The only way to print is to restart the computer everytime. I have an imac and im operating OS X version 10. I h...
The colour cartridge of Canon Pixma E Series E560 Multi Function Printer is almost empty . I need to know the way to reset the colour cartridge ink status .
I am using a Canon iX6820. It was printing fine with the ICC profile sRGB IEC61966-2.1. But after installing a new printer (the same model just a newer one), I had lost the printer profile. I downloaded again and put it in the correct folder Library...
I am at my wit's end. I print out half-fold greeting cards sized 4 1/4" x 5 1/2". I have never had a problem in the past but out of the blue, I started to run into a problem where the front & back (as well as the interior right & left) will not pri...
I have an MG7120 that is directly connected (via a hard cable) to my iMac. I downloaded the most recent drivers and installed them without any problems. The printer was easily recognized and set up as my default printer. Now whenever I attempt to pri...
Hello, Wondering if it is at all possible to connect my chromebook directly to my MX310 via USB. It is not showing up in google's list of Canon printers. It appears I will need a PPD file for this printer. Is one available? I am unable to use goog...
printer see good level of ink in all cartridge, when i do test page not print the part that must be i magenta, cyano and yellow are printed very good and black the same.
I can't get my scanner to work on MX-892. It keeps giving message "Set the PC to start scanning" when I push the scan button on printer and push eith Black or Color button. It alwas work before and would park the scan in the MP Navigator EX area in t...
Hi I have a Canon TS5150 and just today it started throwing up an error saying NO PAPER IN TRAY/CASSETTE - but what happens is it makes lots of strange sounds and takes up the paper then jams it...but reports no paper in tray? ive dismantled, cleaned...
I've got a new TS8020 and just printed my first photos. Unfortunately there are horizontal lines printing. I've gone in and cleaned and deep cleaned..printed nozzle check pattern. Nozzle check pattern is perfect. Please help! Thanks.
My printer works fine when I print from a word processing file, but when I try to print something like a form downloaded from a website, it comes out very faint. These are black and white documents. Any suggestions? I changed the printer cartridge, ...
So I have a Canon Pixma MG6821 printer and I usually never ever have any issues scanning documents. I managed to scan two documents earlier tonight, but as I tried to scan the third one that I need to scan because it is very important...it suddenly s...
| Subject | Author | Posted |
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM | ||
| 12-27-2025 03:38 PM |
