Desktop Inkjet Printers
G3260 borderless
Instructions on manual for paper choice to print Borderless does not match options on computer instuction says paper choice should offer “Borderless” but that does not appear!I print beautiful 8.5 x 11 with border about 3mm but have not been able to ...
ppershan by Contributor
  • 703 Views
  • 0 replies
MX920 won't print black except....
it WILL print if I print to 4 x 6 photopaper. This tells me that the black cartridge print head isn't clogged. All other colors print fine in a 8.5 x 11 format but NO black. Sometime ago, I got to a paper thickness setting (as I recall) to adjust pho...
TR4520 poor quality using scan-to-pdf utility
The printer is 6 to 12 months old, usage is moderate, scan-to-pdf is infrequent. Recently the quality has degraded significantly.Added 12/17The problem wasn't with the scanner. I had copied the originals "on top of the previous copy" several times. S...
imageCLASS D480 Setting MF Toolbox Threshold
Hello,I have a Canon D480 on Windows 7 using Omni Page 18..1When I bring up the toolbox and check the threshold I am always at 72.I want a deeper scan somewhere in the 120-140 range.I also scan legal and letter sizes through the ADF.I can set the thr...
longbid by Contributor
  • 6918 Views
  • 3 replies
Canon Pixma TS6320 Envelopes Off Center
I have a Pixma TS6320 printer. I have latest drivers installed. [TS6300 series MP Drivers Ver.1.02 (Windows) 10/04/21]. I have no problems printing greeting cards, documents, etc. Any envelope I try to print is way off center. The whole left side is ...
bobl61 by Apprentice
  • 2107 Views
  • 2 replies
Printing from Cricut
I have had trouble printing from my Pixma MX472 since the day I bought it.  I have not been able to print Avery Labels and now I cannot print from my Print and cut fuction on my Cricut.  All my settings are for 8 1/2 by 11 but it prints at 4x6 size. ...
MG2522
Hey! HELP!! I have a new MG2522 printer and have been using it quite a bit. Today when printing the text is blurry, to where you can barely read it. I have gone into settings and completed the following without any improvements: alignment, alignment ...
IP6000D printer USB Front Port
I have an IP6000D printer which I love and have no intention of changing. Only problem is the front USB port has never worked (don't really care if it does or not) but after I changed hard drives Disk Management wants me to "Initialize The Disk" befo...
JimHanus by Apprentice
  • 2106 Views
  • 2 replies
PIXMA810 driver compatibility with Big Sur v. 11.6
I have a PIXMA-810 scanner/printer from long ago that I'd like to use now with my current MacBook Air laptop (MacOS Big Sur v.11.6).  Support indicates that there is no downloadable driver for my OS.  However, I do have the original CD-ROM driver ins...
MikeF by Apprentice
  • 621 Views
  • 0 replies
Banding problem in my Canon TS9020.
I have a Canon TS9020, and have been experiencing a persistent banding problem that I haven't been able to solve so far.Here are some comparisons between some photos and scans of the prints that I made from them, so you can see the banding in the pri...
2nCt3Sb.jpg IMG_20211212_0001 (3) - Copy.jpg 1939 New York World's Fair Poster.jpg IMG_20211212_0001 (2) - Copy.jpg
hbenthow by Apprentice
  • 991 Views
  • 0 replies
ScanGear Internal Error 7,202,1
Scans work, but after each scan, I get Internal Error Code:7,202,1.  TWAIN driver.  WIA works without error, but offers lests options.Scanner is Pixima MP250.  Downloaded latest driver from usa.canon already.
BizzyM by Apprentice
  • 5417 Views
  • 4 replies
