Desktop Inkjet Printers
Pixma MG2522 USB connectivity failure
After replacing the color cartridge the USB failed.  Initially the yellow Color Ink LCD was flashing and the green power LCD were flashing.  I had to pull power to the printer to get the tray to go to the middle.  I replaced the color cartridge and t...
Fla5183 by Apprentice
  • 971 Views
Pixma TS6220 showing ''Canon'' on display
Good day,I own a TS6220 printer. I just moved my printer from a table to another one, and now when I turn the printer on, the display only shows ''Canon'' and it stops there. When I moved the printer, it was already off, I unplugged it, moved it and ...
PIXMA iP8720 Roller lines?!
Screenshot_20220729-192645~2.png Can anyone help me out?I have a Canon PIXMA ip8720When I print any type of larger area with black I seem to get these roller lines, or at least that's what it looks like. It's only with black. I'll attach a photo. As ...
PIXMA MX410 5B00 Error
I cleaned my own ink absorber pads myself (not easy since they don't build the ink pads to be very accesible) a few months ago and the printer has been working fine but now it's giving me the EB00 error. I've tried every solution including unplugging...
Pixma g4200 skips lines of text
I have had a reliable experience with my G4200 printer until recently, when it started to skip entire lines of text when printing.I have tried several approaches to fix this issue:nozzle check (black is missing the middle portion)cleaning and deep cl...
Shbird by Apprentice
  • 1583 Views
  • 3 replies
MX922 won't print text
I have an iMac with it's latest OS X 10.11.6 and an MX922 printer. It was working great, but then I tried to also connect my new MacBook Pro Big mistake. Printer not working well since. I deleted the printer in ystem Preferences, dowloaded all new dr...
csut2 by Apprentice
  • 8627 Views
  • 6 replies
G7020 usb thumb drive question
I bought the G7020 thinking that it had a normal USB "A" 2.0 port. However, it appears to only have a USB "B" printer- type usb port. I found an adapter cable - usb "A" 2.0 female to usb "B" male printer adapter so that I can plug in a thumb drive. I...
MG7020 by Contributor
  • 5835 Views
  • 1 likes
MG3620 solid Yellow Light - printer won't turn on
Just took printer fresh out of the box. Took off orange packing tapes and plastics. Took out power plug and pluged it in. Solid yellow warning light stays lit. On button does NOT power it on. Tried different cord from the Epson, does the same thing. ...
qarrykid by Apprentice
  • 3445 Views
  • 2 replies
Pixma TS6420a Low Ink Indication
Does the subject printer have a definite "ink empty" message or just "ink is low" and you have to wait until it actualy stops printing?  My previous Canon printers had an "ink empty" message but I haven't seen one on this printer.
joeber by Contributor
  • 1850 Views
  • 2 replies
Pixma ix6850 will not load paper
Hi, my Pixma ix6850 had suddenly stopped loading paper from the feeder tray. It always starts and then gets stuck almost immdiately - it looks as if it is going into the feeder wonky, with the right hand side (me facing the printer) going in first. I...
paul9 by Apprentice
  • 1785 Views
