Desktop Inkjet Printers
PIXMA MG6320 Scanner stopped working
Hello - I'm having the same issue where my Scanner just stopped working.  "Scanner Utility" is greyed out under "WINDOW" which is odd.  However, I never used that before, when I went to the Canon MG6300 application, I would see an "Open Scanner" tab ...
PIXMA G620 - Prints Have Yellow Cast
Printer is about 1-1/2 years old.  Only about 150 prints made.  Suddenly has made a yellow/gold color cast on photos.  Using Photoshop Elements 2023-Windows 10 Pro.  Tried all the cleaning methods.  Please help
dmjjr by Apprentice
  • 1542 Views
PIXMA MX922 Scanner not working on Mac OSx 14.2.1
I just updated my Apple to MacOS Version 14.2.1.  It identifies the printer no problem, but there is no scanner anymore.  Was wondering if maybe the PIXMA MX922 is outdated for this version.  When I go to scan it says "set PC to Scan". Go to printer/...
GuyC by Apprentice
  • 1101 Views
PIXMA TS702a (brand new) won't print color.
Hi,I just bought a PIXMA TS702a and have it all set up.  It will only print black and white on paper as well as on icing sheets.  I have edible ink loaded into the printer (it is designed to print on food sheets).  I have the print settings set to co...
PIXMA MG3620 Wi-Fi Connection Failed
Hi,  I am trying to connect my printer to my wifi but every time I try and it says connection failed. I have tried multiple tricks based off what I read online with no success. Any suggestions would be great!   Lindsay
lbauer by Apprentice
  • 1187 Views
Pixma iP8720 Top Cover Removal
Need to know how to remove the cover from the iP8720 printer as I need to check the purge unit area. There is something jammed that I just can't reach without taking off the black piece that covers the sides & back of the printer. I see where there a...
Brand new PIXMA G650 print yellow tint on printing.
Sorry if that's a vague title, but I have a brand new G650 that I've just bought and installed on my iMac M1 24 running Ventura. After the initial set up I tried to print sone photos and they came up with a pronounced yellow tint. I then tried one of...
Jonzjob by Contributor
  • 2111 Views
