I am using my printer to print a double-sided image. I am printing the sides, one at a time so after it first print, I flip it over in the right orientation and put it back in the tray. Then after I print my second image I put it into the light and t...
MG3620 purchased ONE YEAR AGO TODAY! Macbook Air, Sonoma 14.6.1, using AirPrint (Wifi) I have downloaded and installed the latest driver from Canon. I have been able to print labels in the past. I pulled up the same template recently to print but ...
I have turned off the ink detection, which is the only setting I've read that I might need to change. I rarely print anything and generally do so in black only. In my early fumbling with the menu I think I chose clean spouts or whatever the right ter...
I purchased my G3260 megatank printer in April 2023. nozzle checks only printed black and cyan. I've done several cleanings and deep cleanings. Now when I try to print it starts to print then gives me the error message and stops. The ink tanks are s...
I first had an E05 error. I pulled out the cartridges and cleaned off the gold contacts and reinstalled.Now I'm getting the P10 error. What can I do? I have no interest in doing the wasteful Cannon Upgrade. I want to fix my perfectly good printer. Th...
I own a canon pixma G3470 ( in the us is sold under the name canon pixma g3272 ). When printing A4 images at the bottom of the paper there are some thin horizontal gray lines. I tried everything clean/ deap clean , bottom plate and roller cleaning. T...
I am having an issue with the color printing after refilling all ink capsules. The black works fine but the color appears light purple. It was working fine prior to refilling the ink. HELP !!
I looked on here, downloaded things I don't think I need, changed the intensity and still every other line prints lighter. It's not an over used printer. I used it today for eight pages, earlier this week printed a card and probably a month a go prin...
I'd cleared a paper jam, and ever since, it won't print now, as the printer constantly says I need to add paper. I've had two other people look the printer over in case I missed something, and they can't find anything.Does anyone have any ideas?
I’ve had this printer since August. It started printing terrible washed out photos. My ink levels were low so bought new ink. The photos are the same. Totally unusable. I have done a deep cleaning. Reinstalled 4 times , checked printer cartridges mul...
Anyone know why my windows 11 is no longer compatible with my canon TR8520 printer?Says it's not compatible with my processer. That has not changed.Intel(R) Celeron(R) N4020 CPU @ 1.10GHz 1.10 GHz, 16GB ram. Canon Pixma TR8520Windows 11 Home 24H2, OS...
So I have a printer and letters on the keypad, except for when I want to connect to the Wi-Fi router box and when I click on the WI. Fi router box instead of saying to type in the password. I just get a blank screen and no letters or numbers. Show up...
HelloI am looking for a megatank printer, I am not really interested in catridge variants, but speciffically those that can be refilled. The printer must also have an ADF (simplex or duplex) and wired ethernet connection, Fax functionality is not man...
| Subject | Author | Posted |
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM | ||
| 12-27-2025 03:38 PM |
