My printer has randomly stopped working. When I try to send something to the printer, it either says "Incoming," or it acts like it's printing and makes a lot of commotion, but doesn't actually print. What do I do? Also, did Canon get rid of its cust...
Hi I have your Canon Mega Tank G3270 and I am having a problem. When a page is finished printing it doesn’t eject fully. If I wait a little longer then the printer reverses the page back in a little and then ejects it fully however, then there is a...
I'm trying to print a UPS label but I can't figure out how to center it or just to be able to move it a little so it prints completely. Where it's positioned, the top and left side cuts off some of the letters. Thanks for ay help!
02-18-2025 03:17 PM Canon G7000 wifi link to 3 W10 PC & 2 W7 PC. Print and scan OK to each EXCEPT one W10 PC. PC sees G7000, auto configured drivers over wifi connection; I can SCAN successfully, but print says sent to printer, but NO Qu...
My scanner was working fine until a week ago. Canon MX410, it began to give me the error code listed above. As mentioned, it can ocassionally preview an image perfectly, but wont save the file. Or it will, but as a blank 54kb BMP, which I assume is a...
Hi, I am getting error 2, 156, 50 when trying to use my new MG3650 scanner. Clearly the scanner is warming up but the message refers to lack of USB or power connectivity both of which are hooked up. (Printing OK). Do we have an answer pls?? Clearly...
I am able to print but I cannot scan except to a USB. I want to be able to scan and save on my MacBook Pro. Sonoma Operating System. Can anyone help? I'm so happy to have found this forum!
why is is my printing, double printing on top an already printed linei has a paper jam and cleared that - realigned all printer heads, and now its double printing totally illegible
I tried to print, but the paper won't load. It seems to kick it back up instead of pulling it into the printer any ideas?
Recently had to relocate my wifi router. We have the printer working with the wifi, but the scanner option will not work. I have gone thru the steps making sure the printer is connected to wifi. Is there another setting on the computer that I have ch...
I had to install the printer on a new device. It printed the test document just fine. But now it has a 1403 error and won't recognize one of the printer cartridges. it is a Canon MX922 printer. I tried removing and replacing the cartridge. Even went ...
Hello. We purchased a Pixma 4722 last September. It worked okay for a while, but about Christmastime it started doublestriking and misaligning horizontally, plus the next sheet of paper would be started and would jam.. I tried to get help but with...
My Canon MG3620 printer has lights that flash green then orange, 7 times. The support article https://support.usa.canon.com/kb/s/article/ART176497 says "Printer error has occurred" and "Service is required." But I can not find the service that is req...
I aligned the heads, cleaned nozzles etc. and even the clear plastic strip and the type is still blurry and double printing so to speak. What's next? Don't want to buy another but will if it's the last resort.
| Subject | Author | Posted |
| 09-08-2026 09:55 PM | ||
| 09-08-2026 05:31 PM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM |
