My canon MX450 Series printer not printing full-size images
I keep trying to print off my computer and I get tiny little images. I never chose to reduce the image! ugh! help!
Hello,Love me my MP560 but suddenly I got the message... 'remove power cord and restart, then contact dealer' (words to that effect). I have now done so numerous times but all it (finally) did was spit out a partly printed doc, then switched off and ...
Everytime I try to scan the screen on my all in one PIXMA MG5620 Printer says the following: "Set the PC to start scanning". - I have installed the Canon IJ Scan Utility2- I have Bonjour/printer network sharing enabled on my Macbook- Everything works...
Hi Canon Community! I am trying to use my PIXMA MG5422 to print on A7 envelopes (5 x 7). I have them loaded in the top tray per the instructions on the printer but every time I try to actually print, they jam. Any ideas?
Hi. my Canon MX892 has started having problems printing photos. Deep shadows are producing blue coloring, not black. Have done manual alighnment, multiple deep cleanings (causing ink supply to dwindle) but no improvement. Here is a sample of the prin...
I have a Canon MX920 printer. Recently reinstalled drivers. I replaced a Canon ink cartridge with a "knock-off" which was instantly recognized. All ink levels look good on the printer read-out. Documents are blank when printing function is comple...
hello, i seem to be having problems with my printer.at first it was the error code B200 which i fixed by lifting the cover and letting the carriage go past halfway and then closing the cover. i had to do this twice. it printed once then started throw...
My iP8720 will not print PDF files. It doesn't matter whether the file was created in Acrobat 8 Pro, Word, WordPerfect. It doesn't matter if the PDF contains images or just text. It does print files from Word and WordPerfect, as well as Photoshop, et...
I'm hooked on the ip4700. I've had two that both eventually died (they had heavy use). I bought a used one on eBay and it works just fine for some things -printing photos, artwork, etc. BUT it won't print correctly from the web! If I try to print ...
Canon PIXMA MX432 printer spooler not running?
This error is not listed in the s/m. Can anyone tell me what it means?
How do I copy a 4x3 photo onto and to fit 5x7 photo paper? Do I have to scan it first into Picasa to enlarge it or can I do that directly from the computer?
I just bought a wireless canon MG2922 printer. It will feed paper, but won't print. I am using the wifi. I think it is hooked up okay. Need help please. thanks
How can I turn off "borderless copy" on the MX922 photo scan settings? I'm trying to scan polaroids (Image Spectra and Polaroid 300 film). Thanks!
| Subject | Author | Posted |
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM | ||
| 12-27-2025 03:38 PM |
