11-01-2014 01:08 PM
Pixma MX922 has two black cartridges, one's big and the other is the size of the color cartridges ? When one gets low, then I have to replace it, it doesn't "switch" to use the other one which has plenty of ink. Why is that ?
What's the point of having two black cartridges ?
11-05-2014 12:23 AM - edited 11-05-2014 12:27 AM
Hi williampeck1958,
The two black ink tanks serve different purposes and are used for different types of printing. The larger black ink tank is a pigment-based ink and is used for your document printing when plain paper is selected, you are doing single-sided printing, and your document contains black text.
The smaller ink tank is a dye-based ink and is used when printing photos, performing duplex (double-sided) printing, and when a paper type other than plain paper is selected (i.e., envelopes, labels, photo paper, etc.). The smaller black ink is also used when printing certain webpages and PDF files that have coding in them to use color ink, even if the grayscale or black only option is selected.
As such, when the smaller black ink tank runs out, you are not able to use the larger black ink tank in its place unless you are able to highlight the text in your doument and change it to all black text. If the larger black ink tank runs out and you still need to print, highlighting the text in your document and changing it all to another color other than black will utilize the smaller black ink tank and the other color ink tanks to make the text on the page.
Also, in the event that you run out of ink and want to prevent the low ink warnings from displaying, you can temporarily disable the ink level detection function of the printer by pressing and holding down the STOP/RESET button on the printer for at least 7 seconds, then releasing it. You will need to do this procedure for each of the ink tanks that are showing that they are low or out of ink for the low ink warning to be completely removed. Once the low/out of ink tanks are replaced with Canon genuine ink tanks, the ink level detection function of the printer will be re-enabled.
Hope this helps!
This didn't answer your question or issue? Please call or email us at one of the methods on the Contact Us page for further assistance.
03-30-2016 01:42 PM
Can you explain why duplex printing uses the smaller cartridge? Is there a way (On the Mac) to specifiy the larger cartridge?
Thanks,
Drew
04-04-2016 11:53 AM
Hi atlynch,
The reason why Canon's printers use the dye based (smaller ink tank) black ink when printing duplex is because it dries quicker than the pigment based ink. If the pigment based ink was used, when the paper is printed on the reverse side, there would be streaks on the paper and ink would smear on the printing platen inside of the printer. Because of this, there isn't a setting in the driver that would force the printer to use the pigment ink for duplex printing.
02-25-2017 02:11 PM
I've kept my MX922 on duplex setting unless I have something I specifically don't want to print on both sides. From the info here I now assume that when I print single black-only pages (much of my printing), that I should have the duplex setting turned off to keep from using more ink from the small black cartridge. Is this correct, or is the printer smart enough to know there won't be a back side to a page?
02-26-2017 09:33 AM
Hi LynnieB,
If you only print one page, the PIXMA MX922 will print accordingly.
10-02-2017 12:04 PM
I hav my settings designated as plain paper with fast print and gray scale but I still use more from the small cartridge than the large one. what else might this be
11-18-2017 12:16 AM
Yes, it answers my question. But how stupid is it to sell the combo pak of cartridges and not include the small black one to print pictures. The other cartirdges are included. Why not Black???? Makes me wish I'd bought a different brand printer, this iP8720 is no dream.
01-07-2018 01:25 PM
Not at all happy with the software changes made for the black ink cartridges. When I first got this printer there was NO problem with this. I love this printer and even got one for my Dad because he was always having problems with his printer and inks. Right after he got his you guys changed the software and now he has a problem again. He's old, he doesn't need to have to deal with this petty issue. I don't want to deal with this. I got the printer because it was easy and low maintenance and the ink didn't run out quickly.... why change what is not broke. His theory is that companies do stuff like this because it makes them more money..... I'm inclined to agree! Does Canon have a color printer that does NOT have to have SPECIAL ink to print things from the internet.... why would you need special ink to print from the internet and other ink to print documents. Why would you have to go to the trouble of highlighting text and changing it to all black or all some other color so that the printer will work? So rediculous. Oh I know, buy TWO printers, or just keep paying crazy high prices.....
Why can't the printer be smarter...if you select print grayscale or print black and white, why can't the printer just use the black ink, period.... only makes sense if the theory of "picky ink means more money" is true.
I wouldn't call me 'dissatisfied' I would say more 'EXTREMELY Disappointed in CANON'
03-23-2018 06:42 PM
I have a MX922 and love it. It's the best printer I ever had. I purchase my ink tanks from 123 Inkjets, where the savings are phenomenal. I have never had an ink clog or smear. Plus their tanks hold more ink, a double savings.
