02-04-2014 10:40 AM
I have been having trouble with my Canon mf4350d. It used to work with no problems prior to upgrade to Windows 8 then 8.1. Printing and faxing work fine, but when I try to scan, the Toolbox program hangs, dims out on the screen and says Not Responding. It's as if the Toolbox program does not work in Windows 8.x. When I remove and reload the drivers and Toolbox software, it works again for the first time but then will not work the second time. Any ideas on how I can fix this? I need a scanner that works all the time.
06-02-2014 03:05 PM
06-04-2014 09:09 AM
06-04-2014 10:58 AM
06-04-2014 11:21 AM
All I can say is...... WHY THE HELL DID CANON NOT SUGGEST THIS! It worked like a charm! THANKS!!!
To all who may experience this painful situation, THIS WORKS! TRY IT. "Mikey Likes it", to coin an old cereal commercial!
Thanks again.
06-04-2014 03:24 PM
You're Welcome!
Thanks for the feedback...I'll use this work-around on my other PC's.
BTW...now the scanner button on Paint doesn't work, but I don't use it anyway : )
06-30-2014 04:46 PM
Thanks for putting your solution out here for others. *fingers crossed* that it keeps working.
06-30-2014 09:35 PM - edited 06-30-2014 09:37 PM
You're welcome.. hope they come out with an update soon.
07-10-2014 04:54 PM - edited 07-10-2014 04:55 PM
@Captret wrote:
Please leave me some feedback before I try it on my other PC's.
Seems to have worked for my MF4150. Thanks!
08-22-2014 03:56 PM
Now it is having a problem with the feeder. It acknowledges that "an original is in the feeder" but then when I do my normal scan (pdf/auto mode) it pulls from the glass. If I change to (pdf/feeder) to force it to look at the feeder, I get an error that says "could not scan because the originals are not placed in the feeder or an error occured".
It's not consistant. Sometimes it works other times it doesn't. Sometimes if I turn everything off and pull usb cord and restart everything and blow a wish on a dandelion and rub my belly while patting my head it works. other times all my lucky tricks do nothing and I have to manually scan the papers in on the glass.
any body else having this happen or at least have some lucky tricks I can use.
Have canon imageclass mf4570dn recently updated to a new computer using windows 8.1. did Captret's for the "system hanging" which worked great. This started happening shortly after that but since it's intermitent I dealt with it but now it's drivinig me crazy.
*fingers crossed* that someone can help.
08-25-2014 02:47 PM
After following the recommendations from Canon to uninstall/reinstall the problem it was only fixed for a short time. A few days later the same problem reappeared where the MF Toolbox program for scanning would hang. This solution by Captret to adjust the properties/settings for WIA fixed my problem too. Thank you! Hopefully it stays fixed.
