02-04-2014 10:40 AM
I have been having trouble with my Canon mf4350d. It used to work with no problems prior to upgrade to Windows 8 then 8.1. Printing and faxing work fine, but when I try to scan, the Toolbox program hangs, dims out on the screen and says Not Responding. It's as if the Toolbox program does not work in Windows 8.x. When I remove and reload the drivers and Toolbox software, it works again for the first time but then will not work the second time. Any ideas on how I can fix this? I need a scanner that works all the time.
05-06-2016 11:40 PM - edited 05-07-2016 12:28 AM
RE: Captret post on 06-04-2014 10:58 AM
A brilliant solution originated by Captret and IT WORKS FOR WINDOW 10!
(For window 8.1) Start> in the run box type. Services.msc
(For Window 10) Press Window icon & R at the same time (window icon + R keyboard), in run box type Services.msc
Scroll down to Windows Image Acquisition (WIA)
Right click, select Properties
Check that Startup type is set to Automatic
Click Log On Tab
Check that Local System account , and Allow service to interact with desktop is checked. Hit apply.
Click Recovery...Click on window next to First Failure, Scroll to Restart the Service. Hit apply.
I tried many solutions but none of them work EXCEPT this one.
At first I thought it is very complicated to setup as instructed. Indeed if follow Captret instructions step by step, it takes less than 5 minutes to complete and MF Toolbox will be ready to use.
Thanks a million!! Captret, you are a genius! Also your instruction is simple and easy to read. x1000 Like!!!
p.s. If you want to give kudo, please give it to Captret (posted on 06-04-2014 10:58 AM)
06-11-2017 04:09 PM
Wow, long lasting thread and Captret's solution still works! I have been using this same printer/scanner since my computer was windows 7 with pretty much no problems. Have been using with windows 10 now for some time as well and just last week started having this issue described here. Have no idea what got it started. followed thread until found this solution and worked like a charm. Weird thing is when went to Windows IMage acquisition log on tab the box next to This account was checked and a password was in the box but have no idea what it was and have no idea what account that might have been there? Anyway, your fix worked for me. Thanks so much!
