07-11-2013 01:36 PM
Whenever I click on the Quick Menu program for the subject product, I get the following error message:
Canon Quick Menu has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
I have uninstalled and reinstalled the driver and Quick Menu software several times, from both the disc provided and on-line downloads.
I have turned off my anti-virus/firewall program and also told the security program that the Canon program is a trusted application.
I am able to print/scan/copy, but not from the Quick Menu, which is more convenient.
Please help.
07-14-2013 10:29 PM - edited 07-14-2013 10:29 PM
Hi clarkdjensen,
There may be a third party scanner driver interfering with Quick Menu. Please try the following:
1. Click 'Start' and then 'Computer'.
2. On the left-hand pane, click the down arrow beside Local Disk (C: ).
3. Click the down arrow beside Windows to open the folder
4. Highlight the twain_32 folder.
5. The folder should have 2 folders that start with PIXMA MX452 and a file called wiatwain.ds. Any other folders or files should be dragged to the desktop.
6. Reboot the computer and try scanning again.
Hi clarkdjensen,
07-20-2013 08:19 AM
That was the problem. Thank you!
07-20-2013 08:20 AM
Karl:
09-13-2013 11:10 PM
I had this same problem with a new PIXMA MG5420. I followed the instructions, but it would not let me move the wiatwain.ds file. It said that I required "permission from TrustedInstaller to make changes to this file". Any suggestions? Thanks!
09-16-2013 12:15 PM
Hi tallbill,
Don't remove the wiatwain.ds file from your TWAIN_32 folder. This is a Windows file used for basic scanning and is required on the system.
Try the steps above again and then perform a test scan. If you can't scan or if you have any other questions, please feel free to Contact Us!
12-19-2013 04:19 AM
Go back through process but the…..
Tallbill (I had same identical problem with same model printer)
step 5: "2 folders that start with PIXMA MX45" I had a folder that said DELL, MG5400 series (only one folder) and the wiatwain.ds mentioned above.
I moved the Dell folder to my desktop
It gave me an administrator prompt
I clicked continue
I did not have to restart I just clicked on software and it launched fine.
01-10-2014 08:57 AM
I have the same probleme but in the TWAIN_32 folder I just have one folder called MX450series and the wiatwain.ds file.
I can print but I can't scan or any other function.
could you help me? thanks
Sylvie
01-31-2014 09:57 AM
I finally found a solution by myself.
As Image Garden and Quick Menu were not working but apparently the device was scanning it meaned that I was just unable to access the files as Image garden was crashing.
I was able to change the parameters in IJ scan utility and specify that after scanning the file should be open in Windows Explorer. That worked out and then I deleted Quick Menu and Image Garden from my system so now I can print and scan.
02-24-2014 04:43 PM
I have a MacBook Air and no CD ROM drive. How do I set up the wifi printing option?
