02-18-2023 12:02 PM - edited 02-21-2023 05:23 PM
My Pixma MX922 is only printing outlines. This is true for both fonts and shapes. I know this probably not a nozzle problem, but I did a nozzle check anyway. The PGBK grid did not print all. The rest of it regarding color was fine. Hope that's a clue.
firmware: "current version" shows 3.031 when I try to update it, it says I already have the latest version 3.041. Which is correct?
computer: Dell Inspiron 15, 64bit, OS: Windows 10
I tried printing from another Dell Inspiron 15, 64bit, OS: Windows 10 with the same result.
This happens with any document I try to print: .pdf, .docx, .jpg, .png
I updated the printer driver on my laptop and this did nothing.
Advice?
02-19-2023 01:38 PM
Problem Solved. I didn't realize that PGBK was the acronym for the large black ink cartridge originally. Once I realized that, I cleaned the nozzles a couple times until the nozzle check pattern was OK. This solved the problem. Apparently, the outline of the font or shape is printed using the BK (small black) ink cartridge and then the font or shape is filled in using the PGBK (large black) ink cartridge. My PGBK nozzle was clogged.
02-19-2023 01:38 PM
02-21-2023 10:06 AM
Hi, rrich3! Thanks for contributing and posting your solution. To date, Canon USA hasn't offered a printer with the model number MP920. So that we can make sure your post helps the right people, can you please double-check your printer's model number?
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
EOS R6 Mark II - Version 1.2.0
08/18/2023: Canon EOS R5 C training series is released.
