07-15-2026 07:08 AM
I am hoping someone can help explain or reproduce this issue because I have spent considerable time isolating variables before posting.
Printers
Computer
Software
Driver
The issue has occurred on multiple brands of glossy printable vinyl, including:
Because the same behavior occurs on different brands, I do not believe it is media-specific.
The printer occasionally produces a soft reddish/magenta halo around black script text.
Important observations:
For example:
The exact same file, printer, media and settings were used throughout.
The following have all been checked:
On the same page there is another text object with the color:
RGB 14,24,36
This text prints perfectly every time with no halo.
Only the CMYK 100% K script text occasionally develops the magenta halo.
Is the Canon G-series driver or firmware using composite black or edge enhancement for K-only vector text when printing on glossy media?
If so:
Any technical explanation or recommendations would be greatly appreciated.
07-15-2026 12:02 PM - edited 07-15-2026 12:04 PM
Number one cause of this is an ink bleed. This occurs when the ink spreads beyond the intended area, causing color mixing. I can also be caused by and alignment issue. If you have done the head alignment and a nozzle check and they both look good, then I suggest an ink bleed. Are you using genuine Canon ink?
07-15-2026 12:41 PM
I've done head alignment and nozzle check. Using genuine Canon ink. Is it possible to have random ink bleeds as it is not every image that has the hallow effect around it?
07-15-2026 04:23 PM - edited 07-15-2026 04:24 PM
Yes, it is possible to have random ink bleeds, which can cause a halo effect around printed text. This issue may occur due to factors like paper quality, ink type, or printer setting. I think we can rule out the ink.
On Canon G7000-series, the paper type setting strongly affects how much ink is laid down and how it behaves on the surface.
If you’re printing from a design app, also try printing from the OS/driver interface with no extra color effects (no “enhance,” no “color correction” overlays) and see whether the halo changes.
Vinyl that’s glossy + inkjet ink can show fringes if the ink hasn’t fully set yet.
If nozzle check for magenta looks fine (clean lines/solid blocks), then it’s more likely a bleed/over-inking issue:
