04-06-2026
08:25 PM
08:32 PM
StevenMOD
MG3620 printer is leaving color ink along the edges of documents did the cleaning and new cartridges
04-07-2026 10:51 AM
Which cleaning did you do? Did you also check and if necessary clean the paper path?
The issue of color ink leaking along the edges of documents from a PIXMA MG3620 can stem from a few common problems:
Running a printhead cleaning cycle is often the first step to resolve ink leakage. This process helps clear any clogs in the printhead nozzles.
If cleaning does not resolve the issue, check the alignment of the cartridges:
