05-31-2022 02:44 PM
Hi!
First time posting here. I have the Canon Pixma MX492. I replaced the black ink cartridge with a new one the other day and used it twice without any problems. Early this morning it started turning off and on by itself. I tried unplugging it and rebooting it and it won't stay on long enough to do anything. It doesn't even give an error message and none of the buttons work. It just keeps turning off and on, off and on. I need this for work! Help!
06-04-2022 04:16 PM
Hi! We've released a firmware update to take care of this issue. Learn more now by clicking HERE.
Hope this helps!
05-31-2022 03:08 PM
Same thing here and I've tried every hard reset technique I can find online. Infuriating as we need to print labels for our business!
05-31-2022 03:34 PM
Looks like there are dozens of us here in the forums with the same exact problem that started around the exact same time. Hopefully Canon can help us out soon. I also work from home and use my printer every day. I need it to work!
05-31-2022 03:34 PM
Based on your description, I would recommend contacting our phone support team for additional assistance. They can be reached by logging into your My Canon Account and going to your support options.
To create a Canon account, please click HERE to for the Canon Account page.
05-31-2022 04:55 PM
It appears it's an issue relating to WiFi. If you can turn off your router, then plug in your printer, it will work, however as soon as you connect the WiFi back to it it goes all crazy again. I'm assuming they keep telling people to call because it costs 19.99 to call and have them help you (according to what it says when I'm logged into my account) this is clearly an update that has a bug. I hope Canon fixes this asap because we can't connect with a cable, we only have phones to use 😭
05-31-2022 05:24 PM
How about you just post the fix for this? Apparently everyone’s printer is doing this.
05-31-2022 05:27 PM
At this point I'm tempted to call and pay the 19.99 just so they can either not fix it and not charge me, or fix it and I'll post the answer for everyone.
05-31-2022 05:47 PM
Same thing happening over here...at the same time. Started trying to print around 5:20 pm on 5/31/2022
05-31-2022 08:44 PM
This is not a solution. Canon must have made a bad firmware update that bricked these - when you call in, you're told to buy a new printer. Absurd. Hope it makes the news. If there isn't a fix in a few days, hopefully everyone throws out their Canon and goes and buys an Epson, HP, or anything but Canon.
05-31-2022 08:54 PM
Same problem here today, happening with MX490, Cannon has obviously put out a BAD update! The only way I got through it was disconnect WIFI, reload printer on computer from CD and DON'T USE WIRELESS! Must be hard wired.
NICE SCREW UP CANON, LAST PRODUCT I WILL EVER BUY FROM YOU! Took me all day to figure out it is CANON's problem.
