11-01-2025
05:00 PM
08:35 AM
I have a new Xfinity XB8 router with a new SSID and a new password. My PIXMA ix6820 is not being detected because the ex router's SSID. How do I change the SSID on my Canon PIXMA ix6820? I tried the WPS button mode on both printer and router several times without success.Thanks
11-03-2025 12:18 AM
You can change your printer's existing network configuration by re-running the printers set up utility.
Canon Support for PIXMA iX6820 | Canon U.S.A., Inc. https://share.google/sZsNXNkaRrKTWKfqi
You can also change the SSID and password of the new router and most (existing) devices will likely connect to it.
11-09-2025 11:38 AM
11-09-2025 11:46 AM
this is why my network has been HappyGiraffe since the early 2000s when a Cisco router gave me that as my default. Adopting new devices and changing routers is so much easier this way!
11-02-2025 11:09 PM - edited 11-02-2025 11:10 PM
Have you considered changing your new router's SSID and password to match your old router?
11-03-2025 12:18 AM
11-09-2025 11:38 AM
Got it. Thanks to all.
11-09-2025 11:46 AM
