08-17-2022 06:14 PM
I lost all drivers during reinstallation of Windows 10. I tried downloading them again, but I still can't print (using my computer). I kept the USB connector attached & the computer was on during downloading--did that foul things up?
Please help.
09-13-2022 03:03 PM
Hello Trader86,
If the printer was connected while the drivers were not installed, it can cause an issue with the setup.
If you continue to have issues after the reinstall, I would suggest contacting support at 1-800-652-2666 for further assistance.
09-13-2022 03:03 PM
Hello Trader86,
09-13-2022 06:37 PM
Before you replied, I uninstalled all Canon-related files with Revo Uninstaller software. Then I downloaded all Canon drivers (including the patch) with the computer USB cable disconnected from the printer. After connecting printer & computer via the USB connector, the scanner worked like a charm. This printer is actually terrific. I find it hard to imagine that the newer products are substantially better than this model.
11-09-2025 05:15 PM
Hello Hector, I hope you are still around. I have the same issue as Trader86, and I followed your clear instructions, but my Windows11 computer says no driver is available, after disconnecting the USB cable and reinstalling the driver per your instructions.. The website says the driver is compatible with Windows11. Unfortunately, support is no longer available for this printer. I'd appreciate any guidance you can give me.
Thanks,
Allen
