03-27-2021 12:46 AM
Got a R6 and would like to continue shooting raw, but do not want to pay Adobe's annual fee. I still use older version of Lightroom. I think this mean I need to convert CR3 to either dng or tiff.
I've installed latest DPP4 multiple times, on multiple hard drives - internal and external. Am getting the same non-responsive application whenever I try to "convert and save". I'm thinking DPP4 not liking high end gaming PC?
Can someone recommend other CR3 converters?
I guess I can always shoot raw+jpeg and save the raw until there is a solution, or DPP5?
03-27-2021 01:33 AM
03-27-2021 09:40 AM - edited 03-28-2021 08:44 AM
@Peter brings up a good point, the DNG converter will work. I undersdtand though you want a streamlined process, the less steps the better.
I use DPP as well, although not as much. DPP seems to like Intel based system's over AMD. I haven't experieneced any performance issues with it. 3 examples below. DPP is great for users who stay within the Canon eco system. The moment however you get a 3rd party lens, the party's over. (All lens correction has to be manual).
Z390 AORUS PRO (F10) \850w, 9900K, 32GB GSkill TriZ RGB - 16-18-18-38, RTX 2080 FTW3 Ultra, 960 Pro_m.2, W10 20H2
Z370-HD3P (F5) \750w, 8350K, 8GB LPX 3200 - 16-18-18-38, GTX 970 FTW SC, Intel SSD, 2TB RAID1, W10 2004
Z97X-UD5H (F6) \850w, 4790K, 16GB Vengeance, GTX 970 FTW SC, RAID0, W10_20H2
Consider DxO's PhotoLab. The R6 is fully supported. Its free to try, and is on sale for easter currently. It has a large following and community of users on PC's Intel / AMD, and MAC if thats your thing. I considered going the perpetual license Lr too, but also wanted something that would continue to be supported, upgraded and sustainable.
04-01-2021 04:14 PM
Since my original post, I've tried Adobe's converter which doesn't recognize R6 CR3 files.
I've also installed trial version of Dx0 Photolab which does open R6 CR3.
Oddly, Luminar AI also started to recognize R6 CR3s. I've been installing and re-installing, DPP and Adobe's converter, I can't tell if one of those helped Luminar or if something from Dx0.
I'm going to continue saving RAW + JPEG, build a new PC for photo and hopefully can get DPP to work on that one.
04-01-2021 05:12 PM
@AndrewYu wrote:Since my original post, I've tried Adobe's converter which doesn't recognize R6 CR3 files.
If you plan to build a PC, I assume that it will be a Windows 10 PC. Before you do, conduct some research into the AMD Ryzien(?) CPU boards compatibility with Canon cameras. It's not.
They do not seem to like to play together. There seems to be some sort of issue related to USB ports on AMD motherboards. I have read that it is a firmware issue. I have also read that the latest AMD boards, just released in 2021, do not seem to suffer the same issues, which is a good thing.
I have always suspected that there was some sort of hardware fault in the design of the AMD USB ports, while others have suspected a firmware issue. The problem is at least three years old, and it should not take three years to come up with a firmware update to fix the problem. Instead, a brand new board design seems to have cured the problem.
04-01-2021 05:19 PM
My current gaming PC is Ryzen about 2 years old and could explain recent problems I'm having. Problems I did not have when I was on old gaming PC which was Intel. I was also using old Lightroom, without the annual dues.
Thanks much for info. I guess I have to dig deeper into comparing AMD vs Intel, even though I was leaning towards Intel.
04-02-2021 10:36 AM - edited 04-02-2021 11:21 AM
Canon DPP seems to also be Intel biased and Intel is what they list in base processor requirements.
I use a pair of HP Z series workstations (Z840 and Z820) for photo and video. They each have a pair of fast multiple core Intel Xeon CPUs and a pair of Nvida workstation graphics cards and handle DPP and Adobe suite well.
The only Win 10 issues I have had related to my cameras was with EOS utility, I use one of the ethernet ports in the workstations for file transfer and until I changed the camera setup to use a fixed IP address I would sometimes run into a problem with the camera being slow to initially connect. This problem usually occurred after one of the frequent Windows features updates. I wish that was the only issue with Windows 10.
Rodger
06-12-2021 02:15 AM
06-13-2021 08:08 AM
Download the latest version of DNG Converter. R6 is supported.
06-12-2021 04:44 PM
