11-01-2024
04:05 PM
08:40 AM
I also put this story at https://www.rsok.com/~jrm/eagle.html
It was challenging to make this photo. I was standing in the blind at at Salt Plains National Wildlife Refuge in Alfalfa County, Oklahoma, United States.
The water level was very low. As a result, the birds were very far from the blind. But, the fish were easy for an eagle to see in the shallow water. There were many, many flying insects between the camera and the eagle. The out of focus insects are not visible in the photo except for the larger ones at about the same distance from the camera as the eagle. Yet the large number of insects refract the light and change the color of the light. The refraction distorts the image slightly.
When editing the photo, I set the white balance to "daylight" even though the sunrise light had more red because 5200K seemed to me to make the photo looked like I remembered the scene. I estimate the distance to the eagle from my camera to be between 200 and 400 meters. (The focus distance reported by the camera includes assumptions about print size and viewing distance as the standard requires and will differ from viewing on a screen.)
I used the free to download Canon DPP software to process the CR3 raw file, but sometimes I use rawtherapee free software and in the past have used darktable. The Apple photos.app included with macOS also works, but I seldon use it. The table below the photo of an eagle catching a fish contains camera settings, things measured by the camera, and a list of all of my edits. When one does "save a recipe" to save a dr4 file from Canon DPP, the edits may be played back in DPP software or listed using the exiftool program. I also used exiftool to list the camera settings and measurements made by the camera.
As a final step to downsize the photo for my web server, I use the graphicsmagick program.
gm convert -verbose IMG_1946c.JPG -resize "60%" -unsharp 0x1 -mattecolor black \ -frame 16x16 -font helvetica -fill white -font \ '/usr/share/fonts/truetype/dejavu/DejaVuSans.ttf' -draw "text 4,1228 \ 'Bald Eagle (Haliaeetus leucocephalus) Bald Eagle (Haliaeetus leucocephalus) is catching a fish at sunrise at Salt Plains National Wildlife Refuge in Alfalfa County, Oklahoma, United States on October 22, 2024, Copyright http://www.r$ -define 'jpeg:dct-method=float,jpeg:optimize-coding=true' -interlace line \ -quality 97 2024oct22_eagle_IMG_1946c.jpg
I nearly always do another unsharp mask after scaling a digital image to a different size.
| Camera Model Name | Canon EOS R5 | |
| Lens Model | EF100-400mm f/4.5-5.6L IS II USM +2x III | |
| Focal Length | 800.0 mm | |
| Exposure Time | 1/400 | |
| ISO | 800 | |
| F Number | 11.0 | |
| Camera Temperature | 35 C | |
| Measured EV | 12.75 | |
| Measured EV 2 | 25.5 | |
| Focus Distance Upper | inf | |
| Focus Distance Lower | 81.91 m | |
| Artist | John Moyer | |
| File:Other | File Name | IMG_1946.CR3 |
| EXIF:Camera | Exposure Mode | Auto |
| EXIF:Camera | Scene Capture Type | Standard |
| EXIF:Time | Date/Time Original | 2024:10:22 08:02:34 |
| EXIF:Time | Offset Time Original | -05:00 |
| EXIF:Time | Sub Sec Time Original | 40 |
| MakerNotes:Camera | Continuous Drive | Continuous, Low |
| MakerNotes:Camera | Focus Mode | AI Servo AF |
| MakerNotes:Camera | Record Mode | CR3+JPEG |
| MakerNotes:Camera | Canon Image Size | Large |
| MakerNotes:Camera | Easy Mode | Manual |
| MakerNotes:Camera | Camera ISO | Auto |
| MakerNotes:Camera | Metering Mode | Evaluative |
| MakerNotes:Camera | Focus Range | Auto |
| MakerNotes:Camera | Canon Exposure Mode | Aperture-priority AE |
| MakerNotes:Camera | Focus Continuous | Single |
| MakerNotes:Camera | Image Stabilization | On (2) |
| MakerNotes:Camera | AF Area Mode | Face + Tracking |
| MakerNotes:Camera | Num AF Points | 1053 |
| MakerNotes:Camera | Valid AF Points | 1 |
| MakerNotes:Camera | Safety Shift | Enable (ISO speed) |
| MakerNotes:Camera | Measured RGGB | 600 1024 1024 489 |
| MakerNotes:Camera | Color Space | sRGB |
| MakerNotes:Camera | Dual Pixel Raw | On |
| MakerNotes:Camera | AF Config Tool | Case 1 |
| MakerNotes:Camera | AF Tracking Sensitivity | 0 |
| MakerNotes:Camera | AF Accel/Decel Tracking | 0 |
| MakerNotes:Camera | AF Point Switching | -1 |
| MakerNotes:Camera | AI Servo First Image | Equal Priority |
| MakerNotes:Camera | AI Servo Second Image | Equal Priority |
| MakerNotes:Camera | One Shot AF Release | Focus Priority |
| MakerNotes:Camera | Subject To Detect | Animals |
| MakerNotes:Camera | Eye Detection | On |
| MakerNotes:Camera | Roll Angle | 0.1 |
| MakerNotes:Camera | Pitch Angle | -1.2 |
| MakerNotes:Camera | WB RGGB Levels Measured | 2001 1024 1024 1931 |
| MakerNotes:Camera | Color Temp Measured | 5162 |
| MakerNotes:Image | Shutter Mode | Electronic First Curtain |
| MakerNotes:Image | Picture Style | Standard |
| MakerNotes:Image | Digital Gain | 0 |
| MakerNotes:Image | WB Shift AB | 0 |
| MakerNotes:Image | WB Shift GM | 0 |
| MakerNotes:Time | Time Zone | -05:00 |
| MakerNotes:Time | Time Zone City | Chicago |
| MakerNotes:Time | Daylight Savings | On |
| MakerNotes:Time | Time Stamp | 2024:10:22 08:02:34.40 |
| File:Other | File Name | IMG_1946.dr4 |
| CanonVRD:Image | Raw Brightness Adj | 0.67 |
| CanonVRD:Image | White Balance Adj | Daylight |
| CanonVRD:Image | WB Adj Color Temp | 5200 |
| CanonVRD:Image | WB Adj Magenta Green | 0 |
| CanonVRD:Image | WB Adj Blue Amber | 0 |
| CanonVRD:Image | Gamma Linear | No |
| CanonVRD:Image | Picture Style | Shot Settings |
| CanonVRD:Image | Unsharp Mask Strength | 3 |
| CanonVRD:Image | Unsharp Mask Fineness | 4 |
| CanonVRD:Image | Unsharp Mask Threshold | 4 |
| CanonVRD:Image | DLO Setting | 50 |
| CanonVRD:Image | DLO On | Yes |
| CanonVRD:Image | Gamma Shadow | 2 |
| CanonVRD:Image | Gamma Highlight | 0 |
| CanonVRD:Image | Gamma Black Point | +0.000 |
| CanonVRD:Image | Gamma White Point | +0.000 |
| CanonVRD:Image | Gamma Mid Point | +0.000 |
| CanonVRD:Image | Gamma Curve Output Range | 0 16383 |
| CanonVRD:Image | DPRAW Microadjust Back Front | -1 |
| CanonVRD:Image | DPRAW Microadjust Strength | 8 |
| CanonVRD:Image | Crop X | 2732 |
| CanonVRD:Image | Crop Y | 1587 |
| CanonVRD:Image | Crop Width | 3000 |
| CanonVRD:Image | Crop Height | 2000 |
| CanonVRD:Image | Crop Rotation | 0 |
| CanonVRD:Image | Crop Angle | 0 |
| CanonVRD:Image | Crop Original Width | 8192 |
| CanonVRD:Image | Crop Original Height | 5464 |
Same bird, same fish, same camera settings
Bald Eagle (Haliaeetus leucocephalus) has caught a fish at sunrise at Salt Plains National Wildlife Refuge in Alfalfa County, Oklahoma, United States on October 22, 2024
11-01-2024 04:54 PM
Nice images John and thanks for sharing the story behind the photos!
Rodger
