10-18-2020 09:11 AM
EOS Utility 3.13.10 on Mac Catalina 10.15.7 does not recognize R5 with firmware 1.1.1 via USB
Image capture sees the photos in the camera
Lightroom can see the photos in camera, tether mode does not work
WIFI connection seems to work
When using USB to connect i have the camera in airplane mode, power saving is off
I have also tried after resetting the communications settings and that did not help.
Also reinstalled the software and that did not work
Please help
10-19-2020 10:48 AM - edited 10-21-2020 09:44 AM
Thanks to all that have responded to this topic, your suggestions have led to me to the solution!
Here is what I have discovered:
When setting this to “Start Automatically.. “ I paid closer attention to what started when I plugged in the camera into the USB port followed by turning on the camera. This is when I realized that another program prompted me to import photos, which I believe prevents the EOS Utility from seeing the camera. Once I quit the offending program and tried to connect then everything worked properly for both settings of the EOS Utility in the menu bar!
The offending program was a NAS utility that keeps shared folder in sync; when something is connected to the USB port it automatically prompts you to import photos. Responding no does not seem to free up the camera for the EOS Utility, however, ImageCapture is able to view the camera photos.
Bottom line: turn off Wifi on the camera, then watch for a program to automatically start when you turn on the USB connected camera. If the started program is not the EOS Utility then stop that programming from running and try to connect again!
Edit: I was able to connect to the camera via USB even with WiFi enabled and airplane mode off. This works for Catalina and Mojave 10.14.6 (Mojave works with NAS utility running, Catalina does not)
10-18-2020 12:13 PM
Airplane mode is not the solution. You need to switch the camera from Wi-Fi to USB mode.
10-18-2020 01:06 PM - edited 10-18-2020 01:07 PM
@Wadizzle is correct airplane mode is not the answer. Only Wi-Fi has to be turned off when connecting to a PC/MAC using a cable.
Canon is apparently serious about helping people not to damge their R5's
Included cable protector - cool
EU Mac - Wired or Wireless:- See page 6
https://gdlp01.c-wss.com/gds/9/0300023299/16/eu-3-13-10-m-im-en.pdf
10-18-2020 03:19 PM
I'm having the same issue with my R6. Disabling WiFi doesn't fix the problem.
As soon as I connect the USB cable, my camera displays the laptop icon and won't let me use the menus in any way. The EOS Utility 3 opens up on my Macbook. But all of the menu options in the EOS Utility are grayed out and so it's useless.
I can get a Wifi connection to work, but that's obviously dog slow compared to a direct USB transfer...
10-18-2020 03:29 PM
Update: So what I ended up doing was deleting the WiFi connection information from my camera and also quitting the Canon connection utility in the top toolbar of my Mac... then I was able to get a USB connection to work after restarting the EOS Utility. Seems like something is indeed getting confused between the WiFi and USB connections, which is silly.
10-18-2020 05:30 PM
@natedogg wrote:I'm having the same issue with my R6. Disabling WiFi doesn't fix the problem.
I am glad to see that you seem to have managed to get it working.
Judging from the above comment in bold text, it sounds like you are connecting the camera while the power is still turn on. That is a mistake. Turn it off, connect the cable, and then turn it on.
10-18-2020 05:37 PM
Thanks, Waddizzle. I was having the same problems irrespective of whether I connected the USB cable with the camera on or off.
10-18-2020 06:43 PM
@natedogg wrote:Update: So what I ended up doing was deleting the WiFi connection information from my camera and also quitting the Canon connection utility in the top toolbar of my Mac... then I was able to get a USB connection to work after restarting the EOS Utility. Seems like something is indeed getting confused between the WiFi and USB connections, which is silly.
You don't seem to understand how it is supposed to work.
You do not start the EOS Utility. It should start up by itself when you turn on the camera AFTER you connect the cable.
10-18-2020 07:35 PM
Does disabling WiFi put the camera in usb mode?
10-19-2020 09:02 AM
@amballin wrote:Does disabling WiFi put the camera in usb mode?
Yes, it should. You must disable it, not merely put the camera into airplane mode.
