04-10-2025 05:52 PM
Running MACOS Sequoia 15.4 - after downloading EOS utility 3.19.0.12 and opening the installer - message extracting files and then Universalinstaller quit unexpectedly.
04-11-2025 07:58 AM
I have same configuration and 3.19 installed OK.
Verify that Universalinstaller has full disk access in the Privacy panel.
Maybe try uninstalling any previous versions of EOSU.
04-12-2025 10:58 AM
Thanks for you response. I was finally able to get EUM3.19.0-installer.app and EU-installet-M3.19.0.12.dmg into the "full access" list. However, I get the same error message. In have all my files in the cloud and have placed the above on my MacBook hard drive with the same resulting error.
04-12-2025 11:02 AM
I suggest you contact Canon support at 1-800-OK-CANON.
04-12-2025 01:37 PM
Thanks, I will give them a call on Monday.
05-03-2025 01:20 PM
I had the same issue and I've worked it out. Here's how:
I encountered similar situations with previous version of EOS utility couple years ago. Someone posted this method online and it worked for me. This same method still works, but I wonder why Canon hasn't solved this already.
